Author Topic: engine running issues  (Read 972 times)
Offline taff-turbo
« on: November 29, 2011, 10:56:26 pm »
Hi!  :smiley:
I've had my (standard) 07 Gti for nearly 4 years with no issues...... til now  :sad1:
Issues: Lacking power
           Sounds like a holed exhaust on overrun (popping)
           Fuel economy not marvellous
           Slight mayonassing on oil cap
           Lumpy idle
Any ideas? split dv, pcv fail, or.......? where do i start? or recomendations for somewhere in peterborough/cambridgeshire to have a look?
oh, and its done 28k and had a major service/cambelt @ vw 1k miles ago
thanks  :happy2:
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: engine running issues
« Reply #1 on: November 30, 2011, 12:26:03 am »
mayo in the oil cap i learned recently is due to the cold weather. my car doesn't do it and it wasn't something i was aware of before. the 2.0T's efficiency drops quite a lot in the cold a well for reasons i can't quite figure out.
sounds like you've got a misfire. you had it scanned?
PLANS: Stage 2+
Offline taff-turbo
« Reply #2 on: November 30, 2011, 01:16:06 am »
not had it scanned yet, good news about the mayo  :happy2: hopefully misfire is coilpack as it should've had plugs recently  :surprised:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: November 30, 2011, 07:14:04 am »
All engines loose some mpg in the cold weather, that's normal. Cold dense air needs more fuel to burn with it.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: December 01, 2011, 01:22:36 pm »
that doesn't make sense tho? more oxygen + more fuel = more power, so you'd have to use less throttle to maintain the same speed, right? so the fuel efficiency shouldn't change.
(sorry this is off topic lol)
PLANS: Stage 2+
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #5 on: December 01, 2011, 01:30:00 pm »
fuel efficiency is impacted greatly due to other factors: long time to bring engine to operational temperature and heating/wipers/heated windshield on... I would say performance wise the colder the better as easier for engine to cool ect ect might be wrong here though
« Reply #6 on: December 01, 2011, 03:07:39 pm »
On the same long run I've found that the car uses more petrol when it's colder.
