Author Topic: Stage 1 doesnt Feel Fast  (Read 5587 times)
Offline csmithy
« on: November 30, 2011, 08:28:00 pm »
Just installed stage 1 bluefin and went out in it staright away and i cant really tell that its made any difference. Is this mormal
Offline chris s
Re: Stage 1 doesnt Feel Fast
« Reply #1 on: November 30, 2011, 08:36:53 pm »
Gti or ed30
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline Boothy
« Reply #2 on: November 30, 2011, 08:43:16 pm »
Faulty diverter  valve I bet. I'd put money on it if you definitely installed the software correctly.
Offline maxload
  • -Given: 41
  • -Receive: 29
  • Edition30 - No.1819
« Reply #3 on: November 30, 2011, 08:53:09 pm »
Going from stock to stage1 you should be able to tell the difference for sure.
Offline Weston
« Reply #4 on: November 30, 2011, 09:15:07 pm »
You should definitely be able to tell  :driver:
GTI going...
Offline csmithy
« Reply #5 on: November 30, 2011, 09:16:14 pm »
gti, yeah installed it right, loaded map of my car and then sent it to blufin and then downloaded new one onto the blufin and the installed to car. does a faulty dv make loads of difference
Offline Boothy
« Reply #6 on: November 30, 2011, 09:39:40 pm »
Yep. I have the GTI myself and have the Bluefin stage 1. I had the same issue though and it felt very little, if not no different at all and the DV is a known weak point. Had it replaced with the VW revision D for about £50 and as soon as I got in it again I knew I'd solved it. Theres no mistaking the difference if you ask me so if you can't notice it something is wrong somewhere and the DV is probably the best place to start.
Might be worth asking a member on the Vagcom thread to have a butchers first if your feeling frugal mate. That might highlight any faults -
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Offline csmithy
« Reply #7 on: November 30, 2011, 09:43:32 pm »
I'll go get one tomorow from vw and see if its any different
Offline Boothy
« Reply #8 on: November 30, 2011, 09:45:07 pm »
Have a search for the guide on here as it can be a bit of an arse to change if your gonna do it yourself unless your tooled up etc.
Offline s2martyn
« Reply #9 on: November 30, 2011, 09:49:15 pm »
Which channel number do I look in?what are we loging here?requested boost verses actual boost?
  • -Receive: 453
« Reply #10 on: November 30, 2011, 09:59:45 pm »
Yup block 115 (requested vs actual boost).  As you're there also log block 106 for fuel rail pressure.
Scan the car for fault codes before you log it.
Offline csmithy
« Reply #11 on: November 30, 2011, 10:00:39 pm »
how do you do that, or do you need vag com
Offline s2martyn
« Reply #12 on: November 30, 2011, 10:08:38 pm »
Yeah bag com logging
Offline csmithy
« Reply #13 on: December 01, 2011, 10:17:04 pm »
changed the dv and went fot a drive. Its a different car now and so much faster
Offline Weston
« Reply #14 on: December 01, 2011, 10:21:31 pm »
Success  :grin:
GTI going...
