Author Topic: RCD510 MDI not reconised  (Read 1477 times)
Offline mano
« on: December 03, 2011, 05:11:43 pm »
Ive retro fitted the RCD 510 and also the MDI armrest
the mdi armrest wont work
ive gone into the can gateway and there isnt an option to enable media 2E  and the only way i find anything about enabling the MDI is in radio > coding > long coding> mdi. But then it says couldnt be reached.
really stuck for ideas?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RCD510 MDI not reconised
« Reply #1 on: December 03, 2011, 05:22:05 pm »
what gateway is it?
early gateways don't have the tick box
Cluster and Key coding
Location Great Yarmouth
Offline mano
« Reply #2 on: December 03, 2011, 05:36:33 pm »
H04 0021 is the code. Its K gateway
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: December 03, 2011, 05:41:42 pm »
It probably doesn't support it, but I know of cases where it worked without coding and it didn't work until it was coded. Is the MDI a newer C or D?
In terms of battery drain it could take a day or two. but the hardware and software version  H004 21 is listed as prone to battery drain.
The other faults on the RCD are due to powering up the unit while not in the car, so they should clear
Offline mano
« Reply #4 on: December 03, 2011, 05:53:25 pm »
Mdi is a D version.
And I am getting no drain as I've used a multimeter on the battery after left overnight
Any ideas on what I need to do?
Offline mano
« Reply #5 on: December 03, 2011, 06:21:23 pm »
When you say not supported does that mean I need to buy a new can gateway off you or re code mine?
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #6 on: December 04, 2011, 05:54:59 pm »
you will need a new gate way . eddy nl has them in the for sale section and can precode them for you
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline mano
« Reply #7 on: December 05, 2011, 08:10:14 pm »
yeah ive got one on the way goign to give that a bashhh cheers tho
