Author Topic: Whats the SPS box all about  (Read 1802 times)
Offline Sug
« on: December 03, 2011, 08:22:04 pm »
Now then lads
Whats the sps box all about?
I know its a switchable control box that runs in conjuction with your remap but where does it sit and how and when can you change the setting
Thanks  :happy2:
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
Re: Whats the SPS box all about
« Reply #1 on: December 03, 2011, 08:47:22 pm »
Doesn't sit anywhere. It's a unit that you plug in to the OBD port. Basically means you can alter between stock, settings A, B, C and valet mode. ABC are settings you can choose and you need to connect to a computer to read/write settings to the device.
You can then use the box, plug it into the port and change the settings. Can't be done on the fly - you have to stop the car and turn off the ignition (and back on) to do it.
In all honesty, the only times I've used are after I've disconnected the battery for too long which wipes the settings.
