Author Topic: TT arms+hubs+BBK wheel spacers=too much width?  (Read 2669 times)
Offline jimk04
« on: December 04, 2011, 03:41:30 pm »
I have some TT arms to go on and thinking of going ally hubs too.
If then I want to fit a bbk and need to space my wheels (currently 17" monza), will I end up too wide and looking stoopid :rolleye:?!
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: TT arms+hubs+BBK wheel spacers=too much width?
« Reply #1 on: December 04, 2011, 06:28:19 pm »
TT arms and S3 alloy hubs gives you 10mm wider track each side, so with spacers you should consider 195 width tyres and you'll be fine  :wink:  :laugh:
Serious, you will be in trouble with stock front fenders and anything bigger than 7,5" width rims if you use spacers IMO of course  :happy2:
Over the top mod list ;o)
Offline jon-tfsi
  • -Receive: 27
« Reply #2 on: December 05, 2011, 10:00:12 pm »
NQS BBK? just a thin shim spacer required with this kit with the 17" Monza.
If your going for TD 1.2.s with a 45 offset it might be a bit close to the wire though. They are available in a 50 offset also. There is a screw on the inner arch that can be removed and a small amount of plastic shved away that will give a bit more clearance
If you go for the s3 brake kit you can use pretty much most 17" wheel and all 18's without spacers. They are heavy though and not really what you would call a BBK
Most other BBK's require a 5-10mm spacer with OEM wheels.
GOLF R Mk7
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #3 on: December 06, 2011, 02:29:35 pm »
My current setup is TT arms and NQSBBK.
IMO the only spacers I would use (and I use spacers) are the hubcentric ones. These add another 10mm of track on each side.
With 7,5x17 ET 50 rim (equivalent to Monza) with 10mm spacers I have a lot of rubbing on the Nurburgring but no rubbing on smooth circuits (my car is not lowered too much, only about 2cm lower than stock).
So:
- this setup is ok with Monzas and 10mm hubcentric spacers but only on smooth circuits (not like Nurburgring)
- using spacers is ok and the car looks great with them. Below is a picture of my car
- I have rubbbing on Nurburgring even with 8x17 ET 50 rims. So buying ET 50 Team Dynamics won't help
The way I hope I am solving the issues:
- I bought 8x17 ET 45 TD (not yet fitted) and hope the rims go over the nqsbbk without spacers
- buy Kerscher front fenders for another 25mm of space.
Cheers  :drinking:
Offline jimk04
« Reply #4 on: December 06, 2011, 06:33:46 pm »
Confirming my thoughts really that to add the arms and hubs - then to squeeze a spacer in too is a bit much!
I think I will go ally hubs in the meantime until I sort a BBK, then revert back to steel hubs when the brakes go on.
This will give me a spare steel hub on the bench to play about with different brakes too!
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #5 on: December 06, 2011, 06:50:45 pm »
There is no increased width (track width) fi you use alloy hub compared to steal hub.
The TT arms go with both hubs. And the TT arms are the ones responsible for the extra track width.
Without using the TT arms a lot of people have BBK with 10mm spacers and no problems.
Offline jimk04
« Reply #6 on: December 06, 2011, 07:41:44 pm »
Oh! :surprised:
I thought the TT arms added some width and the aluminium (S3 type) hubs added some more width?
Offline jon-tfsi
  • -Receive: 27
« Reply #7 on: December 06, 2011, 08:22:46 pm »
S3 hubs have the same geometry as the steel GTI hubs. They are lighter though.
TT hubs i believe add more track
GOLF R Mk7
Offline Carrera2RS
« Reply #8 on: December 06, 2011, 08:23:25 pm »
I had no problems with TT arms and VWR brakes running TD's 8x18 ET45 20mm lower
  • -Given: 243
  • -Receive: 154
« Reply #9 on: December 06, 2011, 10:20:40 pm »
I have read he TT arms add 7 mm and the S3 hubs a further 3mm  :confused:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #10 on: December 06, 2011, 10:39:54 pm »
....and the S3 hubs a further 3mm  :confused:
Do they?  :wink:
"You get what you pay for."
