Author Topic: "Stop! check coolant"  (Read 1446 times)
Offline barlimow
« on: December 04, 2011, 08:50:03 pm »
Got this message intermittently on start-up. Coolant level is fine though. So I assume (both from previous VAG knowledge and a search on here) that it's just a dodgy sensor. Is that right?
If so, how much would it be to get fixed? (parts and labour). I'm assuming a dealer would be somewhat expensive, so any recommendations for good indys in Coventry/Solihull/Birmingham/Leamington/Warwick sort of way would be useful.
Many thanks.
Offline Phil Miller
  • -Given: 86
Re: "Stop! check coolant"
« Reply #1 on: December 04, 2011, 08:53:24 pm »
it does sound like the sensor is furbed mate, its not a massive job to change as for cost if it came into my work it would be about £15 to fit a new one plus the cost of the part
Offline animal
  • .:R32
« Reply #2 on: December 04, 2011, 08:58:22 pm »
Cold weather seems to trip the warning in my R. Stop and start again and it clears.
Offline gazon69
« Reply #3 on: December 04, 2011, 10:49:20 pm »
Its the sensor inside the coolant bottle pal. There prone for failing and i Have the exact same problem. Unfortunately the sensor is fixed inside the bottle so the whole thing has to be replaced. I had a fabia vrs that went and it cost me £14 +vat and about 15mins to exchange. Hope this helps
Offline johntheboy
« Reply #4 on: December 05, 2011, 10:36:12 pm »
I had this on my mk4 years ago, gave the metal prongs on the inside of the bottle a scrape with a screwdriver to clear it of a build up of crap and it never did it again.
Offline barlimow
« Reply #5 on: December 06, 2011, 11:11:53 am »
Thanks for the replies folks, much appreciated. Good to hear the part is cheap, but I dare say the dealer will try to charge me an hours labour for it! And for some more coolant. But will give them a call. I could still do with a good indy recommendation really - I'm not too keen on using the dealers to be honest. Maybe I need a seperate thread for that?
Cheers, will try this first then!
Offline barlimow
« Reply #6 on: December 07, 2011, 08:57:44 pm »
Dealer won't even quote without seeing the car. They want it for an hour to do some "diagnostics". Apparantly that is normally £49+VAT but they will do this for free. And then presumably tell me how many £100s it will cost!!
