Author Topic: Dead battery after RNS-510 installed  (Read 1032 times)
Offline Duke
« on: December 05, 2011, 04:39:33 pm »
Hi all,
I had the RNS-510 version F installed with canbus update for my GTi 2006. Two weeks in and my battery has died. Can't open the boot or anything! I did a long journey only last week (300 miles) so not sure what is going on.
Any ideas? Can I check the canbus is the new one?
« Last Edit: December 12, 2011, 11:09:03 am by Duke »
Offline MarkMarked
Re: Dead battery after RNS-510 installed
« Reply #1 on: December 05, 2011, 08:34:53 pm »
Not sure if the F is any different from the C, but if you have access to VCDS then check that the gateway is a version L or higher
Offline Duke
« Reply #2 on: December 12, 2011, 11:08:42 am »
Hi,
I don't have the adapter unfortunately but the company that fitted it are replacing the canbus so hopefully that will fix the issue. Will let you know if it doesn't  :confused:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: December 12, 2011, 10:12:10 pm »
how much are they charging for the gateway?
Cluster and Key coding
Location Great Yarmouth
Offline pazz
« Reply #4 on: December 13, 2011, 12:15:17 am »
A 2006 will definitely have an old gateway.  They changed around MY07/MY08.
If you use the forum search function you can solve the problem yourself and in the process save money and learn something in the process.
