Author Topic: NGK Iridiums BKR8EIX ***12k mile update on page 13***  (Read 102584 times)
Offline alexperkins
  • -Receive: 99
Re: NGK Iridiums BKR8EIX
« Reply #15 on: December 18, 2011, 07:59:11 pm »
I do, very much  :signLOL:
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #16 on: December 18, 2011, 11:19:01 pm »
There's so many different plugs out there and people rate different ones so im pickled  :scared:
Would these be "the daddy" for stage 2+ eddy?
 :santa:
www.distinctdetailing.co.uk
Offline alexperkins
  • -Receive: 99
« Reply #17 on: December 18, 2011, 11:28:07 pm »
I would say so Jack
Offline jaycue2u
« Reply #18 on: December 19, 2011, 01:37:54 pm »
I assume these are the right type for an 05 GTI?
Offline alexperkins
  • -Receive: 99
« Reply #19 on: December 19, 2011, 01:39:24 pm »
Yes
However if you are not mapped, it should be said a BKR7EIX is perhaps better as this is the same as VWs stock plugs.
Offline jaycue2u
« Reply #20 on: December 19, 2011, 01:41:02 pm »
Im running a stage 1 revo atm, looking to go stage 2 in the new year, so these ones are GTG?
Offline alexperkins
  • -Receive: 99
« Reply #21 on: December 19, 2011, 01:48:05 pm »
Then these are perfect for what you want  :happy2:
« Reply #22 on: December 19, 2011, 01:49:50 pm »
I was under the impression 7's were the ones I needed for st2+ well just ordered these to try thanks for the link!
Mike
Offline alexperkins
  • -Receive: 99
« Reply #23 on: December 19, 2011, 01:55:53 pm »
7s are VW spec, which are a step cooler
8s are step cooler over VW spec and better suited to tuned engines
Also, iridium is a better conductor than platinum which VW use in their NGK Plugs - Iridium is almost as conductive as copper, but has the long life of platinum so its win win
« Reply #24 on: December 19, 2011, 02:08:37 pm »
Will see how I get on with them. Cheers
May not go in till spring when the weather allows the engine to be worked safely.
Warren cox wrote a good post on various tried and tested grade plugs over on VagOc
Offline alackofspeed
  • -Receive: 24
« Reply #25 on: December 19, 2011, 10:29:27 pm »
I found this thread after a bit of searching having noted my car was missing occasionally at idle after a long run at medium to high loads (extended motorway run, with some B-road overtaking for instance). I have the latest revision PCV flying-saucer-esk jobba fitted.
Mine's a stg-1 K03, so I'll report any improvement to add to the thread's statistics. For reference the plugs I removed are 15k old PFR7S8EG and they look in text-book condition. Whatever the outcome 4 iridium plugs for just over £20 makes them pretty much disposable, so cheers to the OP for the tip-off.
Offline cupra_k1
« Reply #26 on: December 20, 2011, 02:16:11 am »
I have been running these for a couple of months now and the car hasn't missed a beat.
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #27 on: December 20, 2011, 07:31:20 am »
Offline muckipup
  • -Receive: 25
« Reply #28 on: December 20, 2011, 10:34:22 am »
Quick question or two - I know that these plugs are sometimes sold as single units (as they appear to be on the ebay link) as they are used in motorbikes. However, I think the bike plugs come with a different gap setting. Is it the same for these or are they preset to 0.8mm like the 4-pack?
Also, there was a post or two about some folks reducing the gap from 0.8 to 0.67mm or something like that on tuned cars. Is there anything behind reducing the gap (as there is a big danger of damaging the delicate tips on these plugs?
The pad damper I'm talkin about ^^
I managed to source 4 of these for my NQSBBK as I was unlucky enough to get a bit of low speed squeel although it may have been a combination of discs, pads and not being broken in enough. These things fixed it no problem anyway.  As a bit of advice, if you are going without the anti-squeel shims, use a non-petroleum based grease on the back of the pads like CeraTec. Copper grease rots the bejeeziz out of the rubber dust seals.  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #29 on: December 20, 2011, 10:43:52 am »
Can you take the brake talk to another thread please, I will clean this up a bit later.
