Author Topic: NGK Iridiums BKR8EIX ***12k mile update on page 13***  (Read 102648 times)
Re: NGK Iridiums BKR8EIX
« Reply #150 on: July 13, 2012, 09:58:17 am »
Cheers Robin, should i use a standard gap of 0.8, or less?
Andrew
....I have no idea, Andrew. I leave all that technical stuff to JKM - I just drive the car.  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=5k4148eipedt7maepi1hbokt0e&/topic,19740.0.html
« Reply #151 on: July 13, 2012, 10:00:40 am »
Andrew
Standard gap should be fine for 99.99% of applications!
Offline gigolo456
« Reply #152 on: July 13, 2012, 10:05:15 am »
Cheers, will i know if it's needs amending lower, ie. any tell-tale signs??
Andrew
« Reply #153 on: July 13, 2012, 10:07:38 am »
Andrew
What power are you running?
h4rdy
« Reply #154 on: July 13, 2012, 10:12:18 am »
Just a bit of feedback.
I fitted some of these about 3 months ago and I think they are shot already.
It won't be the coilpacks as they are fairly new and there is no fault but I think they are just to cold and I get a bit of hesitation at low revs accelerating.
They have been ok but I am going to put the OEM back in and see what happens.
Over and out.
« Reply #155 on: July 13, 2012, 10:15:45 am »
I'm running on NGK Iridium 7's on a Revo Stage 2 K03 GTI and without any problems. I was advised by JKM that 7's were the most appropriate for my mods/power.
« Reply #156 on: July 13, 2012, 10:20:19 am »
Over and out.
have you taken them out? What do they look like?
Offline gigolo456
« Reply #157 on: July 13, 2012, 10:24:55 am »
I spoke to the manufacturer directly last week and they have advised if the 7s are too cold still, there is an exact match but in 6, so i will just see how the 7s today fair!?
« Reply #158 on: July 13, 2012, 10:25:34 am »
Are you running a map or not?
Offline gigolo456
« Reply #159 on: July 13, 2012, 10:37:01 am »
Yes, i have an R Tech Custom Map Stage 2, only had it for about 4 weeks now, and i said, have been running on 6s (Platinum i think) for last 15 mths or so. Idle now is quite rough, ie. since the remap, but that could be down to a number of things, but for £30 or so, i think it might be worth taking a chance, see if it improves!?
« Reply #160 on: July 13, 2012, 10:45:51 am »
15months... how many miles? Plugs will degrade quicker as your running stage 2.
Worth a shot at some new '7's maybe.  :happy2:
« Reply #161 on: July 13, 2012, 10:48:22 am »
....Exactly why I change my plugs every 20k miles.  :happy2:
Offline gigolo456
« Reply #162 on: July 13, 2012, 10:50:21 am »
TBH, i only do about 6000 miles per year, so have done perhaps 8000 in last 15mths or so. I've nothing to lose i guess by changing to the Iridium 7s...
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #163 on: July 13, 2012, 10:51:30 am »
speak with Nick - i think he prefers Nology. they're more expensive tho, £40 a set
PLANS: Stage 2+
Offline gigolo456
« Reply #164 on: July 13, 2012, 10:53:59 am »
did a bit of research on these on ye olde web and kept getting the words 'snake oil'!!  :popcornsoda:
