Author Topic: Electric window lock  (Read 1524 times)
Offline mhurley
  • 5 door 55 plate metallic grey
« on: December 06, 2011, 06:40:01 am »
Hi my electric windows work fine but when i press the window lock button they still go up and down.
The button illuminates when i press it but doesnt lock the windows
Could this be a fuse issue?
Thannks
Offline Dannyboy88
Re: Electric window lock
« Reply #1 on: December 06, 2011, 07:44:17 am »
When you press the window lock button are you still using the window up down buttons on the drivers side? If so i believe the windows only lock if a passenger tries to operate the window from their side of the car. So you can press the lock button set it to the high you want the window at and the passenger cant adjust the window with their button because the lock is on.
