Author Topic: Emergency Brake Flash Light.  (Read 5442 times)
Offline G-Lader
« on: December 06, 2011, 12:11:22 pm »
I was reading through the following thread regarding activating DRL using the fogs and noticed the above was shown as having been activated on a screen shot.
http://www.mk5golfgti.co.uk/forum/index.php/topic,38595.0.html
Can anyone tell me firstly, does it pulse the brake lights quickly if higher than usual pressure is applied or is it activated if the pressure is applied for a set length of time??
Can this be activated on any age / spec of Golf or is a specific controller required??
Does it work like this?
Thanks in advance!
Offline mo
Re: Emergency Brake Flash Light.
« Reply #1 on: December 06, 2011, 12:16:21 pm »
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
Offline G-Lader
« Reply #2 on: December 06, 2011, 12:22:33 pm »
Thanks for the link, that was exactly what I was hoping for.  :jumping:
Next question for some of the techies, can it be activated on a 2004 (54) plate GT TDi???
Thank you!  :happy2:
« Reply #3 on: December 06, 2011, 12:26:28 pm »
Well that I do like  :happy2: Im all for making Brake lights more visible. I had so many close calls on the motorway in bad traffic cos people get too close.
Offline G-Lader
« Reply #4 on: December 06, 2011, 12:43:55 pm »
Yeah, it looks great and will certainly catch your eye hopefully making it safer.
First time I seen it was when watching a bit of footage of the new M5 and 911.  :jumping:
Fingers crossed it's an easy mod.
Offline daboy3000
  • MKV GT TDi
« Reply #5 on: December 06, 2011, 01:25:37 pm »
I'll have a bit of that!!  Especially like the way the hazard light come on, saves trying to reach for the switch at the same time as avoiding something or coming to a standstill on the M25.
Offline G-Lader
« Reply #6 on: December 06, 2011, 02:34:59 pm »
Right where is Darren!!  :party:
Need to find out if it can be coded on my wife's Golf and if not what needs to be changed to allow it to work.
Offline mortygttdi
  • -Receive: 146
« Reply #7 on: December 06, 2011, 03:56:36 pm »
This trick only works on 30byte controllers so even if you have the highline 23 byte module it will not activate,
On the golf if you brake suddenly the hazards flash about 3-5 times and only go has fast has if you pressed the hazard switch.
Darren
Offline G-Lader
« Reply #8 on: December 06, 2011, 04:21:32 pm »
Ah, I knew you would know.
Will it also pulse the the brake lights as per the video posted?
How much would you expect to pay for a 30byte controller and do you have a part number by any chance??  :happy2:
Thank you!
Offline Tamiyoman
  • -Receive: 39
« Reply #9 on: December 06, 2011, 06:30:27 pm »
Eddie-NL activbated this for me on my Ed30 when I was down at his place 4 weeks ago. I think mine is just Hazards flashing when emergency braking, but he might be able to say more?.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: December 06, 2011, 06:36:06 pm »
Yes, Hazards will flash
In the time I have had it enabled only got it once to do it, although it was an emergency stop and the abs kicked in
Cluster and Key coding
Location Great Yarmouth
Offline G-Lader
« Reply #11 on: December 06, 2011, 07:14:23 pm »
Is there anyway to pulse the brakelights as well Eddie?
In the footage posted by Mo, the Mk6 pulses both, could a Mk6 controller be fitted to a Mk5 to allow this function to be enabled?
Thank you!
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #12 on: December 06, 2011, 07:44:41 pm »
Darren
do you know what size controller i have by any chance? i'd love to activate this on my car
PLANS: Stage 2+
Offline mortygttdi
  • -Receive: 146
« Reply #13 on: December 06, 2011, 08:57:03 pm »
Sub im not at home at the moment but will check on that last scan we did?
Check VrsCarls thread regarding cornering fogs there is a list of them,
Ive got them to flash on quite a few occasions  :signLOL: :driver:
« Reply #14 on: December 06, 2011, 09:18:07 pm »
What bit of the scan do I need to check and what piece of data would tell me that I can activate this function?
