Author Topic: Anyone else get this - manual GTI's  (Read 1635 times)
Offline Syrag64
« on: December 09, 2011, 09:25:29 pm »
Hi,
Sometimes when i push my clutch pedal down it stay's down slightly and i have to use my toe under the pedal to get it back up.
If that makes sense?? :signLOL:
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
  • -Receive: 453
Re: Anyone else get this - manual GTI's
« Reply #1 on: December 09, 2011, 09:49:05 pm »
Clutch release bearing sticking??
« Reply #2 on: December 09, 2011, 10:28:16 pm »
Might be master cylinder. Mine had to be replaced under warranty.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #3 on: December 09, 2011, 10:43:04 pm »
I had that after clutch change due to air in the system  :smiley:
Over the top mod list ;o)
Offline Syrag64
« Reply #4 on: December 10, 2011, 12:09:25 am »
Thanks guys, it only happens occasionaly, but i'll get my garage to take a look when its in next week for brakes.
Offline clubsport
« Reply #5 on: December 10, 2011, 09:15:59 am »
Had this a fair amount on old 911's, it can be quite common when they get hot....First step is to bleed the system, get rid of any trapped air, next step is usually rubber seals in the cylinders.
I replaced a slave cylinder on a Vr6, which was cheaper than the last step which would have been the master cylinder.
Someone with more understanding of a mk 5 than me will know if the car has a slave cylinder (i would expect so).
