Author Topic: uho! yellow warning  (Read 6315 times)
Phil Mcavity
Re: uho! yellow warning
« Reply #15 on: April 15, 2009, 07:39:09 pm »
Just drive it gently steve till youve taken it to someone to check it out on VCDS.
Dont go stage 2 just yet, or you could end up with your engines insides dripping on your driveway.
Best be safe then sorry.
More likely the remap has upset the Ecu in some way.
Take it back to the place who did your remap.
« Last Edit: April 15, 2009, 07:41:01 pm by Phil Mcavity »
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #16 on: April 15, 2009, 10:12:28 pm »
CEL light on a stg1 car would indicate a misfire , usually coil packs on the way out or a fuelling issue.
Drive the car normally (no heavy load) until you get the code downloaded. (prob random misfire , or specific cyl)
The light will flash 3 times , then if the problem persists stay lit (and need fault code cleared to get rid of it again)
most likely you need to change your REVO settings , or a coilpack has been pushed over the edge by the remap.
Get the code and take it from there...
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveS
« Reply #17 on: April 15, 2009, 10:14:24 pm »
got no one to check it... thats th eproblem
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #18 on: April 15, 2009, 10:17:17 pm »
put a shout out for someone with VAGCOM near to you , or at a show soon  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #19 on: April 15, 2009, 10:33:21 pm »
Steve did you not have a fiddle with your settings when you first got the map.  :smiley:
Offline SteveS
« Reply #20 on: April 15, 2009, 10:35:36 pm »
yeah but its put to what carl though, b7 t5 f9
SOLD!! :(
Offline garethmk1
« Reply #21 on: April 15, 2009, 10:37:18 pm »
If it occured anywhere near limiter my guess - and it is a guess - as I've had same problem with mine is multiple misfire.
Comes with the remap - if yours is an 08 plate I'd bet quite a lot more on it.
Regards,
Gareth
Mk5 Golf GTi Edition 30 No:- 2101, 3Dr, Tornado Red, Rear Tints, RCD510 & Sound Pack, Arm Rest
Mk1 Golf GTi 16v Helios Blue, Too Many Mods To List .... MY First Car ! Owned Since 1996 !!! NEARLY READY !!!!!
« Reply #22 on: April 15, 2009, 10:40:40 pm »
Quite often the CEL will disappear with a number of ignition key turns but the fault will still be logged.
I know I am not quite local but if I can help then let me kow.
Phil Mcavity
« Reply #23 on: April 16, 2009, 08:00:32 am »
JKM saturday steve :wink: someone im sure will help u down there.
Offline SteveS
« Reply #24 on: April 16, 2009, 09:15:48 am »
bit far to drive for sure if theres a problem...
the light was off on way to work, drove reasonably spirited and it came back on, it has now stayed on. so gonnahave to take it to VW!! bloody great!!
i have a forge spacer which i wanna take off, but dont have the original bolts (shorter ones), do you think they will blame that at all?????
SOLD!! :(
Offline animal
  • .:R32
« Reply #25 on: April 16, 2009, 10:41:40 am »
See if anyone near you has a Bluefin unit or a ScanGauge. They can read fault codes too which would at least point you in the right direction.
Or drop into a your local garage/workshop - most places have a generic code reader these days, chuck them a some beer money and see if they will just scan the codes for you.
Unfortunately, we can only speculate until you can provide a fault code. Have you contacted your Revo dealer?
Offline SteveS
« Reply #26 on: April 16, 2009, 12:04:03 pm »
revo dealer is 60miles away :(
gonna set my revo to 0 and disconnect the battery, see, then take it in to vw if need be
SOLD!! :(
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #27 on: April 16, 2009, 12:27:08 pm »
Steve, stay calm!
Just post for help , Im sure theres someone close with VAGCOM
The CEL is probably due to remap so may not appear in stock mode.
Im not sure a battery disconnect clears the codes anway , does it?
CEL is a way of life with a mapped GTI until its stablised so roll with it  :wink:
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveS
« Reply #28 on: April 16, 2009, 12:55:10 pm »
not sure it does, but hay.. i wouldnt midn taking it in to vw but
a) i dont want them to clear the map, or even tell them, would like to avoid that...
b) the spacer is on and i wanna get rid, but cannot as i didnt get the original shorter bolts back when it was fitted!
SOLD!! :(
Offline SteveS
« Reply #29 on: April 16, 2009, 02:28:33 pm »
right i have a handhelp vw diag thing coming from a friend, so will find the code out... and clear the light
SOLD!! :(
