Author Topic: Boot pop mod - advice  (Read 13137 times)
Offline skard
  • -Receive: 245
Re: Boot pop mod - advice
« Reply #15 on: December 14, 2011, 01:35:34 pm »
Can you direct me to the skoda dealer on ebay, as i would like to order these items also, Thanks  :happy2:
Not a problem, I bought eBay item 320733062892 & asked if he could provide the other bits, which he will :happy2:
Normally I'd order parts in at my dealer as they've always been spot on but it's 15 miles away and I have a lot going on this coming week.
Offline skard
  • -Receive: 245
« Reply #16 on: December 14, 2011, 01:36:22 pm »
Don't go ordering until mine has been packed up  :P
Offline Jaywoo-GTI
  • -Given: 38
« Reply #17 on: December 14, 2011, 01:41:49 pm »
How much did you pay in total if you dont mind mme asking?
Offline skard
  • -Receive: 245
« Reply #18 on: December 14, 2011, 01:46:10 pm »
1K8827761C - 2@£4.63
1J6827439A  - 2@£5.49
6Y0827550C - 2@£16.99
£54.22 delivered for the boot pop kit, plus I got some repair wires and plugs on top.
Offline CAPTAIN BRITAIN
« Reply #19 on: December 14, 2011, 01:54:13 pm »
Thanks, Appreciated   :xmaspresent:
Offline Jaywoo-GTI
  • -Given: 38
« Reply #20 on: December 14, 2011, 01:56:23 pm »
Thanks Skard. :happy2:
Offline ConeKiller
« Reply #21 on: December 14, 2011, 03:44:38 pm »
As they are all part of the same company can you order these parts from a VW dealer or would I have to go to all three?
Offline Matto
  • -Receive: 116
« Reply #22 on: December 14, 2011, 03:48:54 pm »
You can order everything through vw. I did with mine no probs.
Offline ConeKiller
« Reply #23 on: December 14, 2011, 03:56:54 pm »
cheers fella  :xmaspresent:
Offline Lee01
« Reply #24 on: December 15, 2011, 09:20:31 am »
Would anyone happen to know where about in VCDS you change the programming to active the boot to 'Pop' rather than unlock?
Thank you Guys.
Lee
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #25 on: December 15, 2011, 09:36:13 am »
Offline Timvgti
« Reply #26 on: December 15, 2011, 01:46:08 pm »
How comes some complete kits (ball pins, scirocco bumpers, struts and correct vcds coding) work all the time (only not when extremely cold) and others won't work the first time (only when opening manually, closing and trying again)...?
Offline Lee01
« Reply #27 on: December 15, 2011, 09:48:26 pm »
Offline skard
  • -Receive: 245
« Reply #28 on: December 20, 2011, 05:14:12 pm »
Well my boot pop kit came today via DPD and I wasted no time putting it in. Will use the eBay dealer again when I need to order stuff when away from home.
Mod works ok most of the time, backed the bump off with a, anti-clockwise turn and it has responded better, although it is very cold here and it may be affecting it (I hope!). Got going eventually but very slowly to begin with when it does. Think it'll need more adjustment in daylight.
Offline Matto
  • -Receive: 116
« Reply #29 on: December 20, 2011, 06:35:29 pm »
I wouldn't worry too much about it. It will be the cold weather. Mine is the same. Its only because the gas pressure decreases slightly when its cold out.
