Author Topic: Boot pop mod - advice  (Read 13168 times)
Offline skard
  • -Receive: 245
Re: Boot pop mod - advice
« Reply #30 on: December 21, 2011, 07:29:03 pm »
Aye, I see what you're saying.
Used it a few times today and it popped all the way every time.
Even when it just pops a bit it's still handier than before.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #31 on: December 21, 2011, 07:39:28 pm »
I would recommend to fill the socket on the struts with grease
Cluster and Key coding
Location Great Yarmouth
Offline skard
  • -Receive: 245
« Reply #32 on: December 21, 2011, 07:41:16 pm »
Any particular tried, tested and trusted one for this mod?
Offline Matto
  • -Receive: 116
« Reply #33 on: December 21, 2011, 08:19:03 pm »
One other thing I had with mine was the new stops were rubbing on the little black pads causing a squeeking as I was driving. Got the vaseline out earlier and smeared some on the pads and its disappeared  :happy2:
Offline skard
  • -Receive: 245
« Reply #34 on: April 05, 2013, 12:19:35 pm »
Found my old thread as I had a failing strut after only 16 months with not that much use.
The strut has been rattling when driving and hardly working when popped, even when not that cold.
Anyway, before I bin the mod I got two new (pattern) struts off ebay for £15.50 delivered, just put them on and it worked first time, even withoiut me 'pumping' the tailgate and my car is also on a decline with the temp about 2-3C here today.
They are marked 600N, but I'll see how long they are usable for. Being brand new I'd expect them to pop every time anyway.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #35 on: April 05, 2013, 12:40:08 pm »
mine is doing this and driving me nuts only just worked out it was this so not fixed it yet
i spoke to an engineer friend and in his opinion white lithium grease was not the best lube to use due to it being quite thick in lower temps, so suggested liquid silicone or the spray grease in the can which is very thin also.
personally, i do agree with those who have the RVC fitted that this mod is going to work sporadically at best.
Offline JStav
    • Facebook
« Reply #36 on: April 05, 2013, 01:18:29 pm »
Had it done for months but the coding never worked so was an absolutely pointless mod for me  :sad1:
Heard the coding might be different on 05 plates but never found anything concrete on it.  Boooooo!
Silver GTI, Revo Stage 1, R32 rear bumper, R32 exhaust, R32 rear lights, ED30 front splitter, RCD510, Lowered on Eibachs, open fog grills.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #37 on: April 05, 2013, 01:26:40 pm »
I wouldn't and didn't use white lithium grease for this
I had this on my golf with RVC and no problem with it opening, in my opinion if it doesn't work properly it is not installed correctly
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #38 on: April 05, 2013, 02:41:01 pm »
Any linky Skard to said struts?  :drinking:
Offline skard
  • -Receive: 245
« Reply #39 on: April 05, 2013, 02:52:33 pm »
Certainly mate, ebay 150796090490
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #40 on: April 18, 2013, 09:25:42 pm »
Just fitted these new struts today and  :jumpmove: :jumpmove: :jumpmove:
Working again for the first time in about 6 months, even parked facing downhill, opens every time
 :drinking: :drinking:
Offline skard
  • -Receive: 245
« Reply #41 on: April 18, 2013, 09:28:11 pm »
Nice one.
Time will tell to see if it's the 'new' factor or whether they're a more reliable strut.
But at less than half the price it ain't all bad
Offline Timvgti
« Reply #42 on: November 05, 2013, 09:46:14 am »
I removed my hatchpops (skoda struts, Leon ballpins and scirocco bumpers) last winter because it wouldn't open with the cold weather. Then I lost the two scirocco bumpers, so bought two new ones and decided to reinstall everything again last week.
Sadly it doesn't open anymore. Only when I manually opened and closed the hatch (pumping the struts).
But not when I didn't use the hatch for some hours...
How comes? I've tried the scirocco bumpers flat and with one click out.
Temperature is around 50 Fahrenheit in the Netherlands.
How/what can I adjust?
Offline Timvgti
« Reply #43 on: November 12, 2013, 10:53:07 pm »
Anyone?!
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #44 on: November 12, 2013, 10:56:15 pm »
It's a summer weather mod mate... it's well documented that the Boot pop mod is only good when the weather is warmer - I ditched mine.
