Author Topic: Spark plugs  (Read 4625 times)
rileyboy
Spark plugs
« on: December 15, 2011, 08:30:58 am »
Just wondering how often you change the plugs and wot plugs you use as vw said thay won't need
Changing until year8 service my car is a06 gti on 35000 service due on 38000 .
rileyboy
Re: Spark plugs
« Reply #1 on: December 15, 2011, 09:28:29 pm »
No joy
Re: Spark plugs
« Reply #2 on: December 15, 2011, 09:32:33 pm »
Most people recommend every 20,000 especially if you car is tuned.
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Spark plugs
« Reply #3 on: December 15, 2011, 09:53:15 pm »
i'm telling you mate, go for a set of BKR8EIXs
£21.32 delivered and you can fit yourself. no brainer
http://www.mk5golfgti.co.uk/forum/index.php/topic,38720.0.html
PLANS: Stage 2+
rileyboy
Re: Spark plugs
« Reply #4 on: December 15, 2011, 10:19:05 pm »
My car to does not seem to be runing right will now change the plugs myself and let you know the difference
Thank for the advice
Offline seiko
Re: Spark plugs
« Reply #5 on: December 16, 2011, 08:38:38 am »
change the plugs on mine every 12k or every year, not expensive  :smiley:
Offline gti yorks
Re: Spark plugs
« Reply #6 on: December 16, 2011, 09:29:45 pm »
My car has done nearly 50k on its original spark plugs. I expressly asked VW to change them onmy last service but they said it didn't need it.
Basically bullsh*t though because I'm sure its not running as smoothly as it should. I've had new coil packs, DV, PCV and I'm still getting rough idle and rising revs at idle.
i had the rough idle and rising revs at idle a few weeks ago, changed the pcv and was perfect again, only a cheap part to replace, £33 from vw i think it was.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Spark plugs
« Reply #7 on: December 17, 2011, 01:32:38 am »
Plugs should be changed as part of the 4th year service.  :happy2:
Offline edd666999
  • -Receive: 89
Re: Spark plugs
« Reply #8 on: December 17, 2011, 02:04:11 am »
change mine every year
Offline micaerin
  • -Given: 19
Re: Spark plugs
« Reply #9 on: December 17, 2011, 12:21:10 pm »
Are these ok for a standard GTI
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
Offline 56OctyVRS
  • -Receive: 72
Re: Spark plugs
« Reply #10 on: December 17, 2011, 02:19:40 pm »
If you are standard then the BKR7EIX will be fine as they are now the standard heat range vw recommend. The 8s are a grade cooler and normally used in stage 2+ stage 3 applications. The only issue you may find with the 8s is that if you dont drive the car hard. The plugs may foul as they wont get hot enough to burn the deposits off.
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Spark plugs
« Reply #11 on: December 17, 2011, 02:23:30 pm »
got  a set after seeing your review  :happy2:
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Spark plugs
« Reply #12 on: December 17, 2011, 05:59:12 pm »
mine's an A3 2.0T (i.e. a Mk5 GTI in a posher frock) and it works fine on mine. i have plans to go Stage 2 in the not too distant future tho
« Last Edit: December 17, 2011, 06:01:55 pm by sub39h »
PLANS: Stage 2+
