Author Topic: Clutch  (Read 1487 times)
Offline Johnny_tro
Clutch
« on: December 16, 2011, 05:53:47 pm »
Some info. please guys
On my previous car when the clutch was going it was slipping.
On the MK5 GT does this happen when the clutch is low? what are the tell tale signs?
Give or take what the approx cost of fitting one? MK5 2.0 GT - standard not a highender
Offline Johnny_tro
Re: Clutch
« Reply #1 on: December 17, 2011, 11:31:30 am »
Its bite'ing but the pedal seems to go sloppy occassionally or takes a slight press of the gass pedal for it to come back up.....
Offline robby
Re: Clutch
« Reply #2 on: December 17, 2011, 02:48:06 pm »
sounds more like a servo problem than the actual clutch?
Offline vRSAlex
  • -Receive: 253
Re: Clutch
« Reply #3 on: December 17, 2011, 02:54:24 pm »
Does the pedal drop and stay on the floor at all?
The clutch should be good for 150k depending on how its been driven.
Follow AKS tuning on Facebook
Offline Johnny_tro
Re: Clutch
« Reply #4 on: December 17, 2011, 09:20:58 pm »
This is an on/off issue. Worse when cars warm..........
Found it hard to get into first gear once or twice then when I drive and change the cluch seems sloppy.....it does not drop completely to the floor
but its slow/sloppy in getting back up again. Feels soft/spongey
100k car been driven normally......not hard hard.
Offline Syrag64
Re: Clutch
« Reply #5 on: December 17, 2011, 09:30:41 pm »
I have a similar problem in my 75k gti, was led to believe it could be air in the system?
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline Johnny_tro
Re: Clutch
« Reply #6 on: December 17, 2011, 09:32:47 pm »
Hoping its somthing like that.....knowing my luck its going to be ££££
Offline Johnny_tro
Re: Clutch
« Reply #7 on: December 18, 2011, 10:50:27 pm »
up?
Re: Clutch
« Reply #8 on: December 18, 2011, 11:13:05 pm »
Sounds like it needs bleeding to me.  :santa:
Offline Johnny_tro
Re: Clutch
« Reply #9 on: December 18, 2011, 11:25:33 pm »
easy enough to do?
and is there a test I can do to check cluch or servo?
