Author Topic: rcd 300  (Read 1398 times)
Offline biffobear
rcd 300
« on: December 16, 2011, 07:30:11 pm »
i was wanting to fit an amplifier, does the rcd 300 have connections at the back for the RCA cables?. if so any problems i should be aware of?
Offline john87
  • -Receive: 53
Re: rcd 300
« Reply #1 on: December 16, 2011, 09:13:59 pm »
Hi,
No, the RCD300 will not have connections at the back for RCA cables sadly...which is the case with many factory headunits. Your cheapest solution without buying another headunit is to make sure your amp take high-level input (i.e. from speaker leads)
Offline sundance
Re: rcd 300
« Reply #2 on: December 16, 2011, 11:15:14 pm »
The RCD300 sucks balls man :(  (I have one!)  :sick:
Offline biffobear
Re: rcd 300
« Reply #3 on: December 16, 2011, 11:20:48 pm »
mabe i better fit my single din alpine head unit
Offline jaycue2u
Re: rcd 300
« Reply #4 on: December 16, 2011, 11:33:13 pm »
http://uk-mkivs.net/forums/t/297997.aspx
Or you could do this, i have just bought an RCD300 to do this to  :happy2:
Offline biffobear
Re: rcd 300
« Reply #5 on: December 17, 2011, 11:11:24 pm »
wow, i think i will just fit my alpine head unit, a lot less hassle.
