Author Topic: ECS Dogbone Mount Insert  (Read 92990 times)
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« on: November 12, 2008, 01:58:56 pm »
Why
Standard VW layout for engine mounts and composition of lower engine mount leads to excess engine movement under various conditions.
This insert fills the void in the standard lower mount , thereby removing some level of 'slack'.
Suits a std car , but is considered of greater use when additional torque from a remap is added.
Sourcing
Any good GTI tuner will stock these.
I got mine from Awesome GTI
http://www.awesome-gti.co.uk/product.php?xProd=6803&xSec=158
ECS Tuning is proud to release it's dogbone mount insert for the Mk5 platform. The ECS dogbone mount insert works with the OEM rubber bushing to provide a better more rigid connection between the transmission mount and subframe. Less movement in the system will result in smoother shifts and less engine movement under heavy acceleration. Made of a 70A Torque durometer. Kit includes dogbone insert, retaining washer, centering washer and new stretch bolt.
Around £25
I believe theres also a cheap link available from the USA
Fitting
Easy
Remove old bolt , lube up the new insert and fit.
Minimal charge from garage if you dont want to do it.
Only caveat is you need space under the car , so be SAFE!
Other versions
Various other forms of the dogbone are available from other tuners
e.g. Neuspeed (doesnt include the bolt) which can also be of varying rubber hardness.
I have also seen some metal based inserts but these are probably too hard to general road use.
A new bolt can be bought from VW , no concensus as to whether its a one time only stretch bolt or not (although ECS info above states it is!)
Plus Points
Considerably reduces engine movement under all conditions
Car feels tighter
May lead to reduced wheelspin and better control as transition from decel to accel can be made smoother.
Reduced wheel hop /axle tramp type vibrations
Fabulous cost/benefit ratio
Can easily be reversed if reqd
Vastly improves the clutch judder I used to have at the biting point
Minus Points
Does increase the level of vibration felt through pedals/handbrake , although this is very minimal.
For me its not even a consideration.
Summary
This is how it should have come from the factory : GET ONE :  :happy2:
« Last Edit: November 12, 2008, 07:26:05 pm by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Re: ECS Dogbone Mount Insert
« Reply #1 on: November 12, 2008, 02:03:22 pm »
Nice write up John_o
Any chance of that long awaited write up of the anti-lift kit. Cough cough.  :chicken:
Offline 182_blue
  • -Receive: 54
« Reply #2 on: November 12, 2008, 02:09:27 pm »
« Reply #3 on: November 12, 2008, 02:17:52 pm »
 x 3  :happy2:
Got mine and Im very happy with it! No additional vibration either  :wink:
Offline gazbutS3
« Reply #4 on: November 12, 2008, 11:31:09 pm »
x4, had them in both my GTi's and got 1 in the S3, cheap effective mod
« Reply #5 on: November 13, 2008, 06:18:34 pm »
^^^^ Love the hand, TC!!
John - I have the Neuspeed version on DSG GTI and have experienced no vibration at all.
[Do you think I need new batteries? :evilgrin:]
Offline bennylenny88
  • needs moar lowwww
« Reply #6 on: November 14, 2008, 01:39:13 pm »
nicee i want one :(
« Reply #7 on: November 14, 2008, 01:43:41 pm »
nicee i want one :(
....You can get one free if you buy a Milltek performance exhaust.
« Reply #8 on: November 14, 2008, 01:54:37 pm »
Hey thats not a bad deal is it, nearly a grand to stop engine movement.  :laugh: :laugh:
  • needs moar lowwww
« Reply #9 on: November 14, 2008, 02:14:23 pm »
lol i do need a exhaust system though hmmm :P
« Reply #10 on: November 14, 2008, 02:27:15 pm »
Ok i will shut up and leave you in RedRobins capable hands good luck.  :rolleye:
« Reply #11 on: November 14, 2008, 03:46:07 pm »
:evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin: :evilgrin:
« Reply #12 on: November 14, 2008, 03:51:04 pm »
^ This is what can happen without a Torque Insert - A broken exhaust mount bracket. It's surprising how much twist movement the GTI engine has.
  • needs moar lowwww
« Reply #13 on: November 14, 2008, 07:55:05 pm »
mines a 1.4 thou :(
Offline gazbutS3
« Reply #14 on: November 14, 2008, 07:56:15 pm »
The engine will still move about pal, maybe not so much, but it will move
