Author Topic: ECS Dogbone Mount Insert  (Read 90864 times)
Offline gazbutS3
Re: ECS Dogbone Mount Insert
« Reply #75 on: April 08, 2009, 07:34:26 pm »
well i agree it hasnt held up well
BUT
the important 'finger' bits that fill in the voids on the OE mount look to be OK and therefore functioning ok ?
Agreed, but at only 6 months old, that's pretty bad. The disc holds the fingers and as soon as that's gone, the fingers will possibly come out of their void positions?
I'd be interested in seeing some older, higher mileage ones.
I agree its not good,
mine came with a large metal washer that would hold it all in place,       I think
Offline SteveS
« Reply #76 on: April 08, 2009, 07:39:24 pm »
i have a neuspeed one!!! erm, i hope they are made differently!
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #77 on: April 08, 2009, 08:30:02 pm »
Presumably to check the state of the insert you need to undo the stretch bolt - in which case you'll need a new one.
What comes to mind is that how would you tell if the insert was f*cked?
Offline SteveS
« Reply #78 on: April 08, 2009, 08:33:37 pm »
neuspeed tell you to use the original one, which i did, so dont see the problem with taking it out and putting it back. its only a bolt??
SOLD!! :(
  • MUBster DUBster
« Reply #79 on: April 08, 2009, 08:40:39 pm »
Nope...it's a tension/stretch bolt.  The bolt needs to be tightened to a specific torque setting...it's also designed to stretch and lock into place when you tighten it.
Presumably, it also allows a bit more flex than a normal bolt - when the engine moves.
Offline tony_danza
  • -Receive: 112
« Reply #80 on: April 08, 2009, 08:43:29 pm »
:surprised: That's not good!! I wonder if that shows the weaknesses in the ECS, or the extensive amount of movement between the transmission mount and the subframe....
Who knows?
Mine's the ECS one, but I think we need to look into this a bit deeper to see what is the cause? Do they all suffer because of the mount, or does one certain brand fail due to poor compound/quality/design?
A stretch bolt surely can't cost that much to find out the state of our mounts?
Sideways yo!
Offline SteveS
« Reply #81 on: April 08, 2009, 08:43:49 pm »
i find it hard to believe it stretchs and, if it does "lock" only once..
SOLD!! :(
  • MUBster DUBster
« Reply #82 on: April 08, 2009, 08:46:44 pm »
I feel like a mushroom - kept in the dark and fed bullsh*t! That was what I was told...
Offline SteveS
« Reply #83 on: April 08, 2009, 08:48:35 pm »
well i dont know the answer, just find it hard to believe.. so u could be right..  :happy2:
SOLD!! :(
Offline cmdrfire
    • Commander Fire - my blog
« Reply #84 on: April 08, 2009, 09:01:15 pm »
The stretch bolt? It's one use only. Every time you torque up a bolt there's movement between the threads as it locks. Failure to replace could result in shear failure.
Offline SteveS
« Reply #85 on: April 08, 2009, 09:03:48 pm »
well cant explain why neuspeed dont tell you to replace it if HAS to be?
SOLD!! :(
Offline cmdrfire
« Reply #86 on: April 08, 2009, 09:14:24 pm »
*shrug*
I can't say why Neuspeed don't tell you to replace or include a replacement. ECS, VF, and BSH do.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #87 on: April 08, 2009, 09:21:26 pm »
yeah , Gaz your right the ECS has a large washer to hold it all in place.
The damage looks to be caused by movement which Im guessing we all will get , tony just puts his car through more paces lol
ultimately you need uprated eng mounts and a solid bottom mount.
Stretch bolt should be one time only , but many get away without doing so but its not the way it should be done and carries (some) risk of something going awry.
Red ED35 5dr DSG
BLOG | BUILD
« Reply #88 on: April 08, 2009, 11:40:57 pm »
Having seen this thread, mine's gonna get inspected when VWR do my engine mount in a few weeks.
Offline WhiteGTI
  • F-A-S-T
« Reply #89 on: April 09, 2009, 12:10:45 pm »
I'll be sure to get my ECS checked at some point soon too!
2006 E46 BMW M3 - 343hp
