Author Topic: mayo under my oil cap now in dipstick  (Read 11140 times)
Offline bulak
« on: December 20, 2011, 12:49:23 am »
Hi peeps
just got a concern
ive been reading loads about this and it seems to be normal having mayo under oil cap in the colder months
but my worry now its in the dipstick only small amount. The reason why im worried in all threads it says its ok if its at the top
of the oil cap but be worried if its in the dipstick, so im worried  :scared:
i noticed it in mid november this year only had the car since july 2011 i do about 300 miles a week so always check my oil 2-3weeks
i started to clean it every other day for 2 weeks and i would say for the last two weeks not even looked at it until today and notice it was in the
dipstick as well
Car drives normal no problems and coolant has not moved
i do 18 miles one way to work and back so total 36
its 4 miles from my house to motor way then i pretty much drive 60mph on the motorway for 12 miles
it takes about 6-7 miles before the water temp gets to 90c
ive notice cause i got dsg i dont really go over 2000 rpm dont really race the car
once at work car is sat for 9 hours then same journey back.
the other thing i dont get i have two friends with gti's (dsg) as well i made them check.
one has very similar driving pattern as mine with no mayo what so ever
and the other all local but drives like hes just stolen it and hes got a very small amount
so my main question is should i be worried about the mayo in dipstick
thanks
Offline Coe
Re: mayo under my oil cap now in dipstick
« Reply #1 on: December 20, 2011, 08:45:12 am »
This is very common on Golfs in winter. If your car's running perfectly and your not loosing coolant etc don't worry.
It's simply condensation due to the cold weather. If you drove your car for an extended period or drove it harder it would likely not be as bad. Mayo on the dip stick is nothing extra to worry about.
You've answered your own question by the driving you do. Low winter temps, low revs, driven gently, not an overly long commute and most of it on the motorway where you'll be getting a massive flow of constant cold air.
Just keep on giving it your usual checks and if nothing changes (i.e your coolant level changes, poor running etc) forget about it.
Offline seiko
« Reply #2 on: December 20, 2011, 08:49:58 am »
as above, and I would also give the car a oil change  :smiley:
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: December 20, 2011, 10:05:01 am »
Post a pic up showing the colour of the oil on the end of the dipstick.
Follow AKS tuning on Facebook
Offline bulak
« Reply #4 on: December 20, 2011, 10:45:54 am »
Thanks guys
After my journey home last night I did check it
And it did seem as the engine did not give out much heat I put
My hand on the engine not really hot after 18mile drive
I don't have my engine cover on as I have nuespeed induction
Shall a change the oil now or give it few weeks till the weather gets warmer
Cause the same will happen again?
Offline bulak
« Reply #5 on: December 20, 2011, 11:37:49 am »
I will try to put a picture up most likely tomorrow
Offline swgti
  • -Given: 28
« Reply #6 on: December 20, 2011, 02:41:39 pm »
I've just had exaclty the same scare, milky oil and all of a sudden a loss of coolant so feared the worst. Got it checked out and all that was wrong was a leaking pipe, the milky oil on both the filler and dipstick was as stated a lot on here apprently a combination of doing short journies (wife only goes 8m to work) and the onset of the cold weather meaning the excess moisture isn't burnt off properly. Apparently Porsches are really bad for it.
Offline tony_danza
  • -Receive: 112
« Reply #7 on: December 21, 2011, 11:46:09 am »
Short journeys and a dodgy PCV are usually the cause. Far less common, it's coming in from the oil/coolant gearbox heat exchanger.
Sideways yo!
Offline bulak
« Reply #8 on: December 21, 2011, 01:57:15 pm »
thanks i will have to get that checked out
do you know if its expensive to buy had a look on eurocar parts website cant find it unless im looking in the wrong place. Or is it dealer only part
Offline tony_danza
  • -Receive: 112
« Reply #9 on: December 21, 2011, 02:41:25 pm »
It's usually a split bit of hose, a couple of pounds from the dealer. Whip off the engine cover and you should see the venting system - check the crinked looking hoses.
Sideways yo!
Offline bulak
« Reply #10 on: December 21, 2011, 10:55:55 pm »
heres some pics
oil cap
dipstick very hard to get the pics my camera is not that good as its only a small amount
Offline Dario
  • booosting... :)
« Reply #11 on: December 22, 2011, 03:20:31 am »
looks OK ,give it a longer trip ,and it will go away
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
Offline bulak
« Reply #12 on: December 22, 2011, 01:06:45 pm »
Do you reckon it will go away once it's mixed with the oil like it's indicating that on the dipstick
Or will it need a oil change, only had it serviced 3 months ago by awesome gti and it wasn't cheap
Offline Coe
« Reply #13 on: December 22, 2011, 05:17:03 pm »
In answer to your question. It'll be fine. Don't bother changing your oil just because of the condensation. It'll only happen again with the new stuff. It'll disappear after you use the car more or the weather warms up etc. Looking at your pics it's not that bad at all. My mk4 Gti was terrible for it in winter.
Offline tony_danza
  • -Receive: 112
« Reply #14 on: December 22, 2011, 05:34:25 pm »
That's nothing, go on a log run and get it good and hot - all that will evaporate away.
Sideways yo!
