Author Topic: Smell of petrol in my engine oil!!!???  (Read 14313 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=avghhi1d4cr1uia1du9810epda&/topic,19740.0.html
Re: Smell of petrol in my engine oil!!!???
« Reply #15 on: December 21, 2011, 03:55:59 pm »
Had oil and filter replaced today, mech checked it over and couldn't find any faults and assured me it's normal so guess I was being a bit anal :laugh:
Since I've had oil changed gonna get the plugs done at the same time, is there any new revisions with the VW plugs or can I just quote my REG num and take what they have in stock..
 :signLOL: don't worry I was worried about mine too. You'll notice that now you've had the oil changed it smells exactly the same.
Just quote your reg number at vw for OEM plugs!
Offline Black9
  • -Given: 35
« Reply #16 on: December 21, 2011, 04:09:36 pm »
Yes it still smells the same :P
Called VW, £13.40 each for plugs :laugh:
Any ideas if parts suppliers such as dingbro etc would do the same ones for cheaper?
Offline alackofspeed
  • -Receive: 24
« Reply #17 on: December 21, 2011, 05:42:51 pm »
Plugs - have a look at this thread.
You can always get the warmer plug (7) from the same seller if you'd rather.
http://www.mk5golfgti.co.uk/forum/index.php/topic,38720.0.html
Offline Black9
  • -Given: 35
« Reply #18 on: December 22, 2011, 09:46:17 am »
Thanks for the info. I'll check it out. On a plus note after having the oil/filter changed my MPG increased around 4MPG in town driving!  :xmassmiley:
Offline greygti
« Reply #19 on: December 22, 2011, 06:42:23 pm »
It's called fuel dilution its perfectly normal to a degree ,just unburned fuel passing the rings and finding its way back into the sump,that said if to much fuel is passing the rings this can cause ''bore wash''
