Author Topic: Whiteline Anti Lift Kit  (Read 233428 times)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Whiteline Anti Lift Kit
« Reply #330 on: June 08, 2012, 11:13:29 pm »
Is it worth me replacing the subframe bolts with these?
They are cheaper from VW mate by about £5. See Mandy's thread for part no's  :happy2:
....But aren't these ECS bolts a different spec and much better than VW OEM's?
They look like the ones we just bought in a Group Buy here.
I may have missed a thread or two Robin but I was under the impression that the two were the same thing (with a difference in price)?? I'm sure Mandy and a few others just bought the OEM ones which cured the subframe movement & noise.
Just had a look at the group buy, they are purchased from TPS which I believe means they are OEM parts (TPS only seem to sell genuine parts). I may be wrong though  :grin:
« Reply #331 on: June 08, 2012, 11:32:02 pm »
My understanding is that the bolts and spacers we recently bought in the Group Buy are different from the OEM ones and are high tensile non-stretch.
Offline vRSAlex
  • -Receive: 253
« Reply #332 on: June 08, 2012, 11:35:43 pm »
They are OEM Robin and the same you would buy from VW etc.  :happy2:
Follow AKS tuning on Facebook
« Reply #333 on: June 08, 2012, 11:38:53 pm »
....Really? Are they a relatively new version/revision by VW?
How do you explain that these are non-stretch and that earlier ones were stretch bolts? [so I'm told].
Offline vRSAlex
  • -Receive: 253
« Reply #334 on: June 09, 2012, 07:40:39 am »
They are an oem upgrade.  The bolt is used on many vag cars from factory.  I'm sure its the same bolt that's been fitted to the a4's/passats etc for years.
I will check the strength rating of the bolt compared to the one it replaces.
« Reply #335 on: June 09, 2012, 08:05:38 am »
....I only bought them because I thought they were better than on my 05-plate 06-plate car.
Thanks, Alex  :drinking:
Offline vRSAlex
  • -Receive: 253
« Reply #336 on: June 09, 2012, 06:34:45 pm »
If your subframe doesn't and had never moved then there is no point in buying them.  They are a different bolt with a good sized washer on them to spread the load and give more surface to hold, but still an oem bolt but from another car.
« Reply #337 on: June 09, 2012, 06:40:03 pm »
....Too late! I've bought them so I'll use them. Will be interesting to see how tight my existing bolts are.  :happy2:
« Reply #338 on: July 06, 2012, 04:15:26 pm »
Re: WALK and SuperPro:
Apparently, SuperPro used to manufacture the bushes for the WALK - They no longer do. Also, the poly used by both companies is very similar. The cases of WALK insert failure (as Tsi_Mike's example) is about 1 in 500 and, of those, much more commonly in cars driven very hard or on track.
IF anyone experiences WALK bush failure, then the most economic solution (I don't know what WALK's warranty is like) is to buy the appropriate SuperPro bushes which will fit into your OEM consoles (of course you did keep them, didn't you!) and you won't lose any WALK features, so I'm told.
Here are some of Tsi_Mike's example pics:
« Last Edit: July 06, 2012, 04:20:11 pm by RedRobin »
« Reply #339 on: July 06, 2012, 04:18:01 pm »
Yes those WALK bushes were removed from my car.  To be frank they hadn't had that much 'abuse' in terms of fast / hard cornering.
Perhaps the occasional contact with wheel cleaning product?  Not sure.
« Reply #340 on: July 06, 2012, 05:28:05 pm »
What specific product are you alluding to?
« Reply #341 on: July 06, 2012, 05:37:42 pm »
There isn't a particular one. Just that if you have an open Style wheel, an acidic wheel cleaner may have some effect on the rubber?
Offline vRSAlex
  • -Receive: 253
« Reply #342 on: July 06, 2012, 05:43:18 pm »
The wear on Mikes were mainly due to the supplied grease drying up.
My WALK kit had been on my car for nearly 2 years, the grease was still good, but the bushes had started to crack.
I was unaware that SuperPro made the bushes for Whiteline.  I will enquire with SuperPro to see what they say.
« Reply #343 on: July 06, 2012, 06:05:14 pm »
....I was told this by JKM who usually get their facts right. Note that they said that this was only in the early days of WALK.
Offline jedi-knight83
  • -Receive: 41
« Reply #344 on: July 06, 2012, 06:17:32 pm »
acid wheel cleaners are nasty stuff. they will ruin any nice looking brake / suspension metal very quickly.
For regular use i use and recommend autoglym custom wheels (or simply acid free wheel cleaner in its trade form)
