Author Topic: Whiteline Anti Lift Kit  (Read 225552 times)
Offline ArildStavrum
Offline foggy3061
Re: Whiteline Anti Lift Kit
« Reply #391 on: November 09, 2012, 01:26:08 pm »
Yes, it'll work.
The WL bushes are also sold separately and fit the stock consoles.
So all the stock size bushes most likely will also fit the WL ALK console.
Excellent, thanks Bruce. That looks like the way i'll go then - if the Whiteline bushes do fail, in with the standard Superpro bushes in the Whiteline ALK consoles.
2005 MK5 GTI 3dr Tornado Red, OEM+
Offline vRSAlex
  • -Receive: 253
« Reply #392 on: November 09, 2012, 01:28:29 pm »
Yes, it'll work.
So you already have the Whiteline kit?
Follow AKS tuning on Facebook
Offline foggy3061
« Reply #393 on: November 09, 2012, 02:38:12 pm »
Not yet Alex but it looks like a must have handling mod!
Offline vRSAlex
  • -Receive: 253
« Reply #394 on: November 09, 2012, 08:45:40 pm »
Not worth going straight for the SuperPro ALK then?
Pic of the bush showing the offset and the insert quality:
Offline Janner_Sy
  • -Receive: 113
« Reply #395 on: November 10, 2012, 06:39:56 am »
I had the Whiteline ALK on mine with no issues, however i only had it for 20k before selling the car.
given the amount of cars ive now seen that have eaten through the whiteline bushes I wouldnt go that route again.  Superpro seem the way to go IMO
Offline foggy3061
« Reply #396 on: November 10, 2012, 10:25:30 am »
It would probably make sense but i'm not convinced by offset bushes, though I know Superpro are considered the best in terms of polybush quality!
Offline Duke
« Reply #397 on: November 10, 2012, 10:26:48 am »
I was going to change the other two bushes at the same time and think the part number is 1K0 407 182, can anyone confirm this please?
Offline mkviken
« Reply #398 on: November 10, 2012, 07:42:23 pm »
do whiteline not sell apre parts? can the hex spigot bush not just be replaced when it wears out?
i would replace the rubber boot on my bump steer kit but it will no doubt happen again anyway as its not a good design so wont bother.
if the WALK goes tits up i would try and source replacement parts to fix it first
« Reply #399 on: November 11, 2012, 05:22:19 pm »
£68 I think it was for replacement bushes on the WALK
Offline mkviken
« Reply #400 on: November 11, 2012, 06:36:04 pm »
That's not too bad really.
Offline Duke
« Reply #401 on: November 12, 2012, 05:28:22 pm »
Just incase it helps, these were the right ones if anyone changes them for oem ones when doing walk or superpro. They were £27 for the pair at dealer.
Offline Duke
« Reply #402 on: November 20, 2012, 09:02:14 am »
Had the Superpro kit fitted yesterday - what a difference  :jumping: Highly recommended.
« Reply #403 on: November 20, 2012, 09:06:35 am »
....Why not change the OEM rear wishbone bushes for polyurethane ones instead of just new OEM ones? Polyurethane will be much more durable and elastic memory retentive.
Offline Duke
« Reply #404 on: November 20, 2012, 09:09:05 am »
I thought it would be too bumpy/more cabin & dash shake so thought a refresh would be fine.
