Author Topic: Car has no power?????- FIXED AT LAST!!!!!!!!!!!  (Read 24094 times)
Re: Car has no power?????- FIXED AT LAST!!!!!!!!!!!
« Reply #120 on: January 10, 2012, 07:32:11 pm »
Hooray its all fixed not one bit of smoke,I was going a bit on the way home and for got about a corner and had to brake hard :ashamed:
Offline damoegan
« Reply #121 on: January 10, 2012, 07:42:38 pm »
  :jumping:   :driver:
« Reply #122 on: January 10, 2012, 07:44:43 pm »
good job i had them r32 brakes on i went into a sharp right at 70mph :surprised:
Offline robdf2
« Reply #123 on: January 10, 2012, 07:56:46 pm »
it tells the ECU the position of the camshaft, i.e which stroke it is on such as intake/exhaust etc... cam position is important for the ECU to know when to inject fuel.
If the camshaft is out then the output from the sensor still shows as correct, hence no fault code. but cam timing is out so valves are opening/closing at the wrong time.
Thanks for that Dave   :notworthy:
do i take it this sensor just runs off the intake cam?
my exhaust popped and banged for ever when my timing was out and also my car ran rich with the timing being pulled , my fuel consumption was utter crap  , since the timing has been put right fuel is good about 50 more miles to a tank  no more popping  :smiley: and importantly no missfires (touch wood)
Where my timing was out my intake valves looked like detonation was occuring and leaking back behind the valve heads leaving a ring of caked on crap around the valve seat.
Also i had the same overuse of silicone sealent and oil leaks from the head  :sad1:
2008 Chrono yellow Cupra
« Reply #124 on: January 10, 2012, 08:35:31 pm »
I couldn't find a dealer in germany willing to get in the special 'tool' to check the cams / timing when I had the pesky misfire.
I'm still interested in having it checked tbh
Offline PDT
  • -Receive: 142
« Reply #125 on: January 10, 2012, 09:13:25 pm »
Can check it by sight, or borrow the tool from a local garage. Not much work to take the cam cover off for a quick check.
Offline heavyd
  • -Receive: 29
« Reply #126 on: January 10, 2012, 09:21:01 pm »
http://www.lasertools.co.uk/item.aspx?cat=316&item=3879
Offline martziniuk
« Reply #127 on: January 10, 2012, 09:53:22 pm »
£87 inc on fleabay
« Reply #128 on: January 10, 2012, 09:58:35 pm »
Thanks both ^
Useful posts.  :happy2:
