Author Topic: RS4 fuel valve help  (Read 4616 times)
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
RS4 fuel valve help
« on: December 21, 2011, 09:16:20 pm »
I've got my Other bits and bobs ready for stage 2+ but I'm worried about the RS4 fuel valve I got the part number off the for by having a search and bought one, is is meant to look like a peice of threaded bar with a hole in the middle  :signLOL: thought it may look like a valve  :laugh:
How do I go about fitting it and were does it fit? I'm doing a THS cooler soon so would it make ease of access when I'm fitting the cooler or doesn't it matter? I've heard it's a PITA to fit but I don't even know we're it goes at the moment  :notworthy:
Cheers guys
Jack
www.distinctdetailing.co.uk
Re: RS4 fuel valve help
« Reply #1 on: December 21, 2011, 09:24:28 pm »
It's the brass fitting at the underside of the intake manifold.   :smiley:
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #2 on: December 21, 2011, 09:29:34 pm »
That looks like the bit! Under the manifold?! Does it have to come off?
Offline gillm
« Reply #3 on: December 21, 2011, 09:38:23 pm »
thats it , have fun fitting it ! it took me a hour to do and loads of skin missing lol
west tuned gt28 @ 340hp
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: December 21, 2011, 11:06:32 pm »
just out of interest i read somewhere that it's worth fitting this on all versions of tune if you're getting the cam follower inspected/changed.
what are people's views on this?
PLANS: Stage 2+
« Reply #5 on: December 22, 2011, 08:12:09 am »
IMO only needed for stage 2+ cars...
Offline Jaywoo-GTI
  • -Given: 38
« Reply #6 on: December 22, 2011, 09:00:05 am »
Would it have any benefit of fitting one of these without a uprated HPFP?
« Reply #7 on: December 22, 2011, 09:55:03 am »
Not really as unless your map is requesting 130 bar it would be wasted.
Standard valve cracks at 130 bar whilst the rs4 one is 136 bar.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #8 on: December 22, 2011, 01:11:41 pm »
ah ok. i vaguely remember reading on here that the valve gives out in the mid range, and can cause fuelling issues which are improved with the RS4 valve
it was more of a "it's not a very expensive part, so you might as well do it" type of thing
PLANS: Stage 2+
Offline baldwined30
« Reply #9 on: December 22, 2011, 01:37:31 pm »
I tried fitting this, gave up after two attempts! Get someone else to do it. Nothing like the cam follower. Thats meant to be changed regularly. This is a pig. Most people who are running stage 2+ need it, apart from that, dont bother. I only changed mine as it was making a noise. changed it a the noise disappeared.
Ed30
Offline kiddfrost
« Reply #10 on: December 28, 2011, 10:11:00 pm »
I did mine and it took me about 3.5 hours, that's with grinding down spanners, making a trip to Halfords after getting too happy with the angle grinder and lots of just staring at the engine.
Would I do it again.... No!
I wish I'd just paid BDM an hours labour to do it.
I only changed mine to try and get rid this whooshing type noise... made fook all difference to the noise but my butt dyno told me the car did go a little better.
Offline gillm
« Reply #11 on: December 28, 2011, 10:15:05 pm »
yep cutting down spanners is needed for this job . unsure how this would make any difference to any noise ? its a pin hole type valve
Offline kiddfrost
« Reply #12 on: December 28, 2011, 10:39:25 pm »
I'd tried everything else and the noise was really annoying me. I only changed it because I'd read on this forum that it cured the type of noise that I was getting so I gave it a go. It worked for them but unfortunately not for me. On the + side I'm sure performance improved slightly so I'm glad I did it.
Offline RS6BRIT
« Reply #13 on: December 29, 2011, 03:10:49 pm »
I dont suppose you guys mind posting up the part number do you ? I need to do this prior to the remap and its the only bit i haven't fitted yet.
LEON CUPRA FOR SALE
Offline AwesomeHassan
« Reply #14 on: December 29, 2011, 03:17:52 pm »
These are a pain to fit! After having mine fitted, i did feel a diffrence. We have them in stock if you want to give us a shout
Hassan
