Author Topic: RNS 510 firmware 4020 and 3980  (Read 9456 times)
Offline flyboy1976
« on: December 24, 2011, 01:11:22 pm »
Two questions....anyone tried or been able to obtain the 4020 F/W yet and what are the differences with 3980 over 3970? I think I read somewhere it was a Skoda RNS specific improvement...is this correct?
Happy Xmas  :santa:
« Last Edit: December 24, 2011, 01:43:15 pm by flyboy1976 »
Re: RNS 510 firmware 4020 and 3980
« Reply #1 on: December 24, 2011, 01:40:09 pm »
Ha Skoda improvement I like that.  :xmassmiley:
Offline alexperkins
  • -Receive: 99
« Reply #2 on: December 25, 2011, 03:32:55 pm »
40xx is for D and above units
The 39xx software is for B and C units
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: December 25, 2011, 05:40:20 pm »
The 4xxx series firmwares are currently factory install only. There are a few H revision units starting to come through which have HW Version 61 and Firmware 4xxx series installed. I'm led to believe these are 40gb / faster processor models and include DAB/DVB. I haven't physically seen one yet (only pictures) so can't comment if that is true or not.
What I can tell you is it will only work on the following model RNS at present:
1T0035680D
1T0035680F
1T0035680G
3T0035680B
3T0035680C
3T0035680D
7F0035680A
7E0035680A
As with the 3xxx series originally only working on C revision units, give it a few months and a version will be released to work on previous versions. I think you will find that all support for both A & B revision Units will dropped same as all support for A revision units was dropped with 3xxx firmware.
So by my reckoning the firmwares will go something like
A Revision units - All firmware up to 284x
B Revision units - All firmware from 110x up to 398x
C Revision units - All firmware from 268x up to 398x currently with support for 4xxx series to come at some point
D Revision units - All firmware from 3xxx onwards
HTH
Carl :happy2:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #4 on: December 25, 2011, 08:43:55 pm »
Be interesting to know about the H units having DAB/DVB.. Eddie-nl has had one for a few weeks so maybe he could shed some light on this
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: December 26, 2011, 11:20:50 pm »
Finally fitted my H unit today, nothing new to report. Came with V8 maps installed and no new options in the coding.
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H61 3970
   Revision: AB001001    Serial number: VWZ6Z7L8327133
   Coding: 04000442040000210000
   Shop #: WSC 00152 210 91233
   ASAM Dataset: ------------------------- ------
   VCID: 33611918922E776
No fault code found.
Cluster and Key coding
Location Great Yarmouth
Offline pazz
« Reply #6 on: December 27, 2011, 01:02:39 am »
Rumours, rumours. Wait till somebody has a DAB capable unit first. The unit versions seem to be changing regularly at the moment, every few months or so. Unlike the days of A/B's.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #7 on: December 27, 2011, 10:13:15 am »
You already can (and have been able to for some time) specify a RNS-510 with DAB in a Golf and a Skoda Superb. The Superb also has DVB(T)
Offline Snoopy
  • -Given: 31
« Reply #8 on: December 27, 2011, 01:41:04 pm »
So is it an add on for the DAB or a different version again?
Offline pazz
« Reply #9 on: December 27, 2011, 05:07:09 pm »
Actually, I take my comment back, I've heard some evidence from a Czech user over on VWNavi that there has been several DAB sample units found.
