Author Topic: Bluetooth Query - please help  (Read 10269 times)
Offline Squeeguk
« on: December 25, 2011, 01:39:42 pm »
Hi Guys
Been trying to find the Can Gateway on my Jetta to verify the part number and stumbled across what seems to be a bluetooth module under the drivers seat.
The problem is, I cannot find a bluetooth signal when I search with my Iphone 4. The part number on the module is 3C0 035 729F. Anybody got any ideas?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: Bluetooth Query - please help
« Reply #1 on: December 25, 2011, 05:32:18 pm »
It's listed as a telephone control module and "bluetooth" aerial, but the option codes suggest it's the control module for the dash mounted cradle only.
Do you have highline dash or the cradle to the left of the head unit?
Offline Squeeguk
« Reply #2 on: December 25, 2011, 06:20:32 pm »
I have the Highline Display, but no cradle to the left of the Nav unit.
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #3 on: December 25, 2011, 06:25:00 pm »
I presume you have no phone menu on the high line?
Offline Squeeguk
« Reply #4 on: December 25, 2011, 06:27:18 pm »
Not sure, but didn't notice it in there. Let me double check quickly.
Offline Squeeguk
« Reply #5 on: December 25, 2011, 06:29:39 pm »
Yep, definitely no phone option there.
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #6 on: December 25, 2011, 06:36:35 pm »
Really needs a VCDS scan to confirm its all connected, but sounds like to me it previous had the cradle on the dash and this has been removed at some stage.
Offline Squeeguk
« Reply #7 on: December 25, 2011, 06:39:47 pm »
Ok, will see if there is someone in the area who can help me out with that. I am about to fit the RNS 510, along with a MFSW with DSG paddles. Looks like I might have to just replace the module with a new one and then get the coding done in one hit. From what you are saying it seems like this module will only work with the cradle?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #8 on: December 25, 2011, 07:07:19 pm »
From ETKA says it's a bit unclear, as the description says bluetooth but the code options doesn't list bluetooth  :confused:
Whereabouts are you based?
Offline Squeeguk
« Reply #9 on: December 25, 2011, 07:29:44 pm »
Based in Camberley, Surrey. Do you perhaps know anyone around here at all?
Thanks for all the assistance.
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #10 on: December 25, 2011, 08:10:15 pm »
I am in Guildford a fair bit myself so not too far, if not have a look on the register thread in the VCDS section  :happy2:
Offline flyboy1976
« Reply #11 on: December 25, 2011, 08:35:32 pm »
I had phone cradle and crappy VW UHV... I replaced mine with Skoda UHV as advised by many on here, works fab with Highline/RNS510 and all latest smart phones i.e Android/IOS.  Its probably the best way forward, not sure what the kit sells for now but with all the right parts it can be nicely monuted underneath drivers seat and with some simple coding via VCDS its an easy fit. Dont forget for Skoda UHV you will need the version B for red dot matrix on the highline or you wont be able to interact with the phone via the MFSW/Highline just on the RNS (if you have one?)
Offline Squeeguk
« Reply #12 on: December 25, 2011, 09:25:02 pm »
Excellent, thanks for the info. I am assuming it would be one of these:
http://www.uvworldwide.co.uk/ice-navigation/vw-golf-mk56-skoda-seat-mfd2-rns-510-premium-bluetooth-kit-p-3159.html
http://www.uvworldwide.co.uk/ice-navigation/vw-golf-mk56-skoda-seat-mfd2-rns-510-premium-bluetooth-kit-p-2304.html
Seems like the B is for rsap phones only, while the A is for both non and rsap. I have no idea what that is, but they mention it. I want something that is going to display on my red MFD, the RNS 510, be controlled from the steering and / or RNS and has A2DP. I have no idea which one will do all that for me. Any advice?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #13 on: December 25, 2011, 09:37:41 pm »
Offline Squeeguk
« Reply #14 on: December 25, 2011, 09:49:53 pm »
Ok, thanks, but it seems that does not do A2DP. If I were to fit one of the other units, would they work, but just not show up in the MFD? Wow, this is turning into a minefield. My wife has the Clarion NX501E in her car, a brilliant piece of kit, and I am trying to emulate those functions in the Jetta. I could do without the MFD display so long as A2DP and everything else works.
Looking at this one, it says it will work with cars with red MFD:
http://www.carsystems.pl/vw-bluetooth-kit-7p6035730f-retrofit,id219.html
