Author Topic: Going into 5th gear  (Read 1432 times)
Offline reflex11
Going into 5th gear
« on: December 26, 2011, 11:48:27 am »
lately I've noticed going into 5th gear I have to hold down the clutch much longer than usual.. otherwise when releasing the clutch it was jerk hard.. any idea why?
Offline vRSAlex
  • -Receive: 253
Re: Going into 5th gear
« Reply #1 on: December 26, 2011, 03:13:41 pm »
Is this just in 5th gear?  I would give the clutch a bleed through first and if it still does it then look at changing the slave cylinder.
Follow AKS tuning on Facebook
« Reply #2 on: December 26, 2011, 03:16:09 pm »
Did you get hold of an ecs bleed Valve Alex?
Do you know how much a gear oil change would be on my visit?
Offline reflex11
« Reply #3 on: December 26, 2011, 07:27:19 pm »
It's just going into 5th from 4th when I release the clutch it jerks kind of hard, I have no idea where the clutch fluid or where to check for it :X
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #4 on: February 07, 2012, 12:17:14 pm »
The clutch fluid shares the same resevoir as the brake master cylinder.  Unfortunately, if you let the level drop a bit low (from normal wear of the brake pads) and fail to top it up, the clutch can get starved of fluid, and cause probs.
