Author Topic: retrofitting headlight washers - got some loose wires...  (Read 2196 times)
Offline apples12
« on: December 26, 2011, 08:22:39 pm »
hi all....
in the process of going all-oem on my lighting setup, headlights ready to go in, auto-levelling loom made, plumbed in just waiting for sensors to arrive from the states, headlight washer wiring plumbed in but a little stuck on where its all got to go...
i've plugged the violet wire into pin 35 of the cluster
ground loop goes to ground
then i've got a red/white wire loose and i'm not sure where thats got to go
also got a relay with two wires (both grey) coming out of it, again, unsure where thats supposed to go.... if someone could help point me in the right direction of where they belong that'd be great
once this is all done and dusted i will be posting up a 'list' of part numbers on how to make the xenon auto-levelling loom from the parts counter including approximate wiring lengths, i managed to make the loom for the cost of 2 connector housing, 6 connector pins and the xenon range module which the scrappy removed with the wiring - i will post up the pinout of this also along with wiring colours :)
thanks
MK6 GT TDI  - CW - LUX pack
GONE
Offline skard
  • -Receive: 245
Re: retrofitting headlight washers - got some loose wires...
« Reply #1 on: December 26, 2011, 08:36:55 pm »
Hey
Did you get my PM reply last week? It has the pinouts in it. Not got it to hand at minute but it's in the Kufatec instructions.
Offline apples12
« Reply #2 on: December 26, 2011, 08:39:00 pm »
Hi
yup i did thanks  :smiley: was working off that, i'm just stumped as to which exact plug the red/white wire go into and where the relay wires go (either i'm too tired or it isnt very clear!)
GONE
Offline skard
  • -Receive: 245
« Reply #3 on: December 26, 2011, 08:50:29 pm »
Hello mate
Sorry having a brainfart after too many JD's, red/white goes in the relay itself pin 8. Grey into fuse pin 34, that'll be the grey and is it 20/30a fuse you need?
If you're still on with this tomorrow I'll go have a look  :happy2:
Offline apples12
« Reply #4 on: December 27, 2011, 04:13:07 pm »
Hiya
so that red/white wire off the main 'engine' loom plugs into the smaller relay 'loom' into 'pin 8'?
then from the relay, the grey wire goes into the fuse box pin 34
and the little wire coming out of the relay goes where?
GONE
Offline skard
  • -Receive: 245
« Reply #5 on: December 27, 2011, 04:35:44 pm »
Is this other gray wire skinnier, and is it meant to be the yellow one to go to CECM block D8?
Offline apples12
« Reply #6 on: December 27, 2011, 05:00:34 pm »
it is skinnier and it quite possibly is the one meant to go to the CECM because as it stands i have no other wire going to the CECM...
right now i've got the following worked out:
MAIN LOOM:
RED/WHITE --> pin 8 of RELAY
Brown --> GROUND
Violet --> Pin35 of instrument cluster
Relay Loom:
Large Grey wire --> Pin 34 of fuse box
small grey wire (yellow on some looms by the look of it) --> CECM D8
correct?
GONE
Offline skard
  • -Receive: 245
« Reply #7 on: December 27, 2011, 06:16:49 pm »
Aye that looks right  :happy2:
Wouldn't be the first time Kufatec have used a different colour to the instructions - does the grey cable have YELLOW stamped on it?
Have a look at the loom in this thread, see if the your grey is the yellow one in this http://www.mk5golfgti.co.uk/forum/index.php/topic,10291.0.html
Offline apples12
« Reply #8 on: December 27, 2011, 06:39:04 pm »
cheeers for that bud  :smiley:
gna wire this in tomorrow after i attempt to figure out if its possible to properly mount the headlight washer relay into the cecm rather than have it freely floating, at the moment my cecm wirings a mess! got fogs, rain/light sensor, dimming mirror, cruise all retrofitted so far, just got xenons/headlight washers/levelling left then gotta pickup a set of seats and im happy with it :)
GONE
