Author Topic: vcds fault codes help  (Read 5826 times)
Offline jackarooney
« on: December 27, 2011, 04:56:01 pm »
got a few fault codes that have came up since i installed crusie control stalk any ideas?
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 ET    HW: 028 101 184 3
   Component: R4 2,0L EDC G000SG  5803
   Revision: 12345678    Serial number: VWZ7Z0D9199878
   Coding: 0000072
   Shop #: WSC 00046 000 00000
   VCID: 79FDE9D74949
1 Fault Found:
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
            P1699 - 000 -  -  - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023170
   Shop #: WSC 00046 412 08192
   VCID: 3A7F36DB0CCF
1 Fault Found:
01486 - System Function Test Activated
            000 -  -
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 K
   Component: ClimatronicPQ35 061 0201
   Shop #: WSC 00000 000 00000
   VCID: 2F69178FC78D
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000527672
   Coding: E5890F0600041800001400001400000000
   VCID: 387B2CD332C3
   Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Part No: 1K0 955 559 K
   Component: RegenLichtSens 002  0505
   Coding: 00217125
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0M AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD08JFKA
   Coding: 0012365
   Shop #: WSC 00046 412 00000
   VCID: 2A5F069BFC6F
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000042
   Shop #: WSC 00046 412 31129
   VCID: 306B14F3DAB3
1 Fault Found:
01044 - Control Module Incorrectly Coded
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 960 L
   Component: KOMBIINSTRUMENT VDD 3354
   Coding: 0001401
   Shop #: WSC 00704 067 57207
   VCID: 326F1EFBD4BF
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001042070043
   Coding: 3D0F0B40070001
   VCID: 2759FFAFEF7D
1 Fault Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 8
                    Reset counter: 27
                    Mileage: 197242 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:02:25
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3354
   VCID: 326F1EFBD4BF
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0113
   Coding: 0000052
   VCID: 306B14F3DAB3
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 E
   Component: EPS_ZFLS Kl.0       1202
   VCID: 2E570A8BC087
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 S
   Component: 0W KSG              0560
   Coding: 82FC12087F2D8505C85AC61000
   VCID: 408B44336A13
   Component:   Sounder No Answer
   Part No: 1K0 907 719
   Component: Neigungssensor  002 0002
   Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
1 Fault Found:
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 316D11F7D1B9
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C530083F69B
End   ---------------------------------------------------------------------
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: vcds fault codes help
« Reply #1 on: December 27, 2011, 07:12:10 pm »
did you disconnect the battery when you did the cruise?
Have you tried to clear all the faults?
Cluster and Key coding
Location Great Yarmouth
Offline jackarooney
« Reply #2 on: December 27, 2011, 07:32:21 pm »
yes i disconnected the battery and yeah i have cleared the faults but they come straight back. :(
is there away i can test the cruise control without driving it? ie via vcds? will the cruise light on the dash light up if its staionary? so i know if it wired up correctly?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: December 27, 2011, 08:41:30 pm »
Where pins did you fit the wire to?
Offline jackarooney
« Reply #4 on: December 27, 2011, 08:48:10 pm »
just tried coding the cruise control again and it works  :jumping:
but i still have the fault codes  :sad1:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #5 on: December 27, 2011, 09:25:41 pm »
Did you use that code from the other thread to put into your engine coding?
Offline skard
  • -Receive: 245
« Reply #6 on: December 27, 2011, 09:48:28 pm »
Other faults...
Is your alarm siren dead? Lock the car with the remote, open drivers door with key, when the alarm is triggered if only the lights flash outside, then there's a good chance your sounder's gone.
Have you started the ABS function test? This won't go away until it's completed. I did this once a couple of years ago, ended up going into an empty car park at night doing figure of 8's. More info here http://wiki.ross-tech.com/wiki/index.php/ESP_System_Function_Test_%28Conti/Teves%29
Offline jackarooney
« Reply #7 on: December 27, 2011, 09:56:49 pm »
yes i used the codes of the other thread :)
no my alarm doesnt work properly it was broken into a couple of months ago and all it did was flash the lights lol
think i need a new siren for it.
not sure what i done regarding the abs lol
Offline skard
  • -Receive: 245
« Reply #8 on: December 27, 2011, 10:00:11 pm »
Is your ESP light refusing to go off? Even after you've put steering on full lock both ways and driven forward slowly?
If you carry out the procedure in the link it should help you with that.
Siren has definitely gone, easy to replace.
