Author Topic: Help - Very strange air intake / boost leak running issue  (Read 14060 times)
Offline alexperkins
  • -Receive: 99
Re: Help - Very strange air intake / boost leak running issue
« Reply #15 on: January 29, 2012, 02:49:51 pm »
6 was the old spec, VW changed the spec to 7 as 6 was too warm
8 will be one step cooler than VWs current spec
You shouldn't need to adjust the gap
If you are K03 stage one however, use NGK 7s.
Offline jedi-knight83
  • -Receive: 41
« Reply #16 on: January 29, 2012, 02:55:52 pm »
yeah a lowly k03 :) and just stage 1 with cat back exhaust fitted and intake to be fitted.
I'll stick with the ngk7's then... although I can get the ngk8's for slightly cheaper ..... if cost isnt an issue would you still say ngk7's?
Offline alexperkins
  • -Receive: 99
« Reply #17 on: January 29, 2012, 02:58:14 pm »
The 8s can be too cold for a KO3 if on stage 1. 8s are more so recommended for stage 2 upwards on KO3  :happy2:
Overall though, the iridium IX sparks are about as good as it gets. Conduct almost as well as copper, but last as long as platinum
  • -Receive: 41
« Reply #18 on: January 29, 2012, 03:05:52 pm »
excellent thanks for your advice. NGK7's it is. I'm not overly confident this is the source of my problem as like I say they were only changed July 2011. However new sparks wont harm things and will just rule one more thing out.
Offline alexperkins
  • -Receive: 99
« Reply #19 on: January 29, 2012, 03:07:39 pm »
Mine were replaced in March 2011, and by November they were ruined (if working right to begin with that is!!)
  • -Receive: 41
« Reply #20 on: January 29, 2012, 03:13:00 pm »
Thanks not right for them to be shot so quickly though surely? Suggests other running issues?
Offline alexperkins
  • -Receive: 99
« Reply #21 on: January 29, 2012, 03:14:16 pm »
A bad map ruined them I think. Over fuelling made them soot up and overheat
  • -Receive: 41
« Reply #22 on: February 03, 2012, 01:08:45 pm »
just changed the spark plugs to the ngk7s. The ones i took out were VW ones and didnt look bad at all. The service book says they were changed about 7k ago and it certainly looks like thats the case.
The coil packs were all the new F revisions as well and this ties in with the fact that vw say there are no outstanding recalls on my car so possibly these were changed before I bought the car.
Wonder if its still worth changing them?? just to rule them out really? Visually they all looked fine. No discolouration or burning like ive seen on some peoples photos on the web.
Not sure what to do now.
« Reply #23 on: February 03, 2012, 01:48:03 pm »
See if the plugs fix it first. Also most peeps go for the VW,oem plugs, as lots of the aftermarket ones can also cause slight running issues too.  :happy2:
  • -Receive: 41
« Reply #24 on: February 03, 2012, 02:01:37 pm »
grrrr.... well i chose the ngk ones after lots of people seemed to rate them and say they were the ones to go for!
Offline alexperkins
  • -Receive: 99
« Reply #25 on: February 03, 2012, 03:25:11 pm »
Ngk7s are the same as vw ones, but are iridium rather than platinum  :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #26 on: February 03, 2012, 03:27:51 pm »
And also even though a spark plug looks ok it can still be faulty!
Offline Boothy
« Reply #27 on: February 03, 2012, 05:55:47 pm »
Have you checked the DV and the cam follower? I
  • -Receive: 41
« Reply #28 on: February 03, 2012, 05:58:02 pm »
dv was changed a few months ago for the latest version.
not sure what or where the cam follower is or how i would check it
  • -Receive: 41
« Reply #29 on: February 06, 2012, 12:22:25 am »
im getting bored of this...
So the problem is still there.
It drove fine on my 15 min test drive after changing the sparks. It drove fine on a 40 min drive at varying speeds on the m11.
The driving back tonight i stuck the cruise on 80 and drove for about 35 mins and then dropped in speed and when i put my foot down again (in 6th in manual) it started doing the hesitation and lumpy running.
Each time its done it.. its been after a decent run at around 80mph .. a couple of times on cruise and once just keeping a steady speed with the throttle. Thats the only similarity I can think of.
I tried to take a video but it doesnt show how 'lumpy' it feels.
What you can see is it sort of surge a bit when i put my foot down and then the revs drop a bit and then slowly continue to raise... but as they are slowly raising it feels very hesitant and lumpy. Its hard to see.
I had it in manual mode on the dsg
