Author Topic: Battery drainage issue?  (Read 6416 times)
Offline MJR
« on: December 29, 2011, 01:02:26 am »
Hey fellow forum members,
Write this as once again my battery is dead! Car has only been sitting for a few days, went to use it today to only get the annoying ticking noise (again lol)
Has this problem a while back, so took it to the garage and they said it was the battery and that the alternator was charging fine, so got a new battery (Oct/Nov 11)
but even since changing the battery, the car has been the same.
If the car is left for more than say 2/3 days, it struggles to start and any longer than a few days the battery is dead.
So I must be getting battery drainage from somewhere but don't have a clue as to what could be causing it.
Before anyone says about upgraded HU, already read all about it.
I recently changed from the RCD300 to RCD300 mp3 and car was the same before I changed it.
Anyone else had this issue of battery draining for no reason or know anything about it?
I have a "05" GTi.
Cheers MJR  :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Battery drainage issue?
« Reply #1 on: December 29, 2011, 10:08:33 am »
Hi
Have you done any electrical mods to the car?
Have you got a multimeter?
Cluster and Key coding
Location Great Yarmouth
Offline MJR
« Reply #2 on: December 29, 2011, 03:35:17 pm »
Hi
Electrical mods? as in?
No don't have a multi-meter.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #3 on: December 29, 2011, 04:09:29 pm »
Interested to see if you get an outcome as I had a similar problem end of November and shelled out and had a new Bosch battery fitted and the problem went, but knowing my luck it's something that might return so will be good to find out
Offline MJR
« Reply #4 on: December 29, 2011, 04:17:05 pm »
It's doing my head in  :signLOL:
Honestly can't figure out what it could be.
Offline MJR
« Reply #5 on: December 30, 2011, 11:53:13 am »
Anyone?
Offline mb
  • -Receive: 29
« Reply #6 on: December 30, 2011, 01:18:32 pm »
The light in the boot on one of my old cars (not a VW) didn't switch off and drained the battery. I'm sure I've also read about the light in someones glovebox staying on and draining the battery. Might be worth checking both of those.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: December 30, 2011, 01:25:07 pm »
What I would do is disable as many items as possible, try to pin down where your issue is.
Also get someone with vag-com to check to see that the modules are shutting down
Offline MJR
« Reply #8 on: December 30, 2011, 01:29:03 pm »
Worth a try  :smiley:
I have VCDS but don't know how you do that part "check to see that the modules are shutting down"
Offline MJR
« Reply #9 on: December 31, 2011, 12:17:27 pm »
Had a good look round the car today and can't figure out what it could be.
May possibly have to go to dealer, to see if they can sort it boohoo!
More wasted money!!!!!!!!!
Offline golfman
  • -Given: 17
« Reply #10 on: December 31, 2011, 12:36:53 pm »
Took mine to the dealer when my battery was suffering,cost me £320 for them to find nothing until i gave them all the modification fuse positions and then they said the battery was showing much better results!!!
ended up being the heated washer jets were on a permanent live when they should have been an ignition feed!!!
scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline MJR
« Reply #11 on: December 31, 2011, 12:46:04 pm »
scott
Exactly, wasted money.
But don't have any other options and getting bored of a dead battery after 2/3 days.
Offline skard
  • -Receive: 245
« Reply #12 on: December 31, 2011, 01:42:07 pm »
Have you added any electrical systems, or the previous owner?
Handsfree kit, footwell lights, hardwired 12v charger and so on?
Look at the rear of your fuse box next to steering wheel for wires that aren't in the loom of wires going into fusebox (if you have any it's likely to be a retrofit and possibly in a constant not ignition live).
As mentioned, take parcel shelf out and ensure boot light goes off with the locks. Push the plunger on glovebox for same diagnosis.
Have you got anything permenantly in 12v socket? Are there any lights that stay on when locked other than door LED?
A good auto electrician would be cheaper than VW and as effective.
Offline MJR
« Reply #13 on: December 31, 2011, 07:21:18 pm »
I haven't added anything.
This battery issue has only started happening in the last 6months or so.
Checked the lights, all go out fine.
So god knows  :signLOL:
Offline MJR
« Reply #14 on: January 02, 2012, 04:30:56 pm »
Ohwell, thought someone on here might have had the same issue, must just be my car  :signLOL:
VW garage here I come.
Kinda looking forward to when it goes to a new home now :happy2:
