Author Topic: Rear De-wipering  (Read 1803 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Rear De-wipering
« on: December 29, 2011, 04:52:20 pm »
When fitting a wiper blank, is there anyway of deactivating the rear wiper and rear wash? Or is it a case of unplugging and blocking washer pipe like on my olf mk4 i had once...
Dom
Diesel Daily Hack.
Offline RENNTAG
  • Premium Performance Parts
Re: Rear De-wipering
« Reply #1 on: December 29, 2011, 04:54:22 pm »
Ye think its just a case of removin the components. Gonna do mine when the roads are a bit cleaner  :smiley:
Offline Zaf2616
« Reply #2 on: December 29, 2011, 06:36:58 pm »
I think there's an option in VCDS that tells the car if a rear wiper is installed or not. Can only assume this turns the rear wash off an all
Offline Matto
  • -Receive: 116
« Reply #3 on: December 29, 2011, 10:11:11 pm »
There is a coding option in the steering controller that tells it if it has a rear wiper installed so yes you are able to code it out.
Offline RENNTAG
« Reply #4 on: December 30, 2011, 08:39:18 am »
Does it NEED to be coded out?
I dont have vcds. If i just removed the components and blacked off the washer fluid pipe woulf this cause any problems?
Offline Matto
  • -Receive: 116
« Reply #5 on: December 30, 2011, 09:10:10 am »
Tbh I don't know if it needs to be done or not. Best thing to do would be to try it without coding it out and see if it throws a fault. Just make sure the pipe is blocked off properly incase you forget yourself and try washiing the the window.
Offline pitsirikas
  • -Given: 19
« Reply #6 on: January 01, 2012, 03:11:18 pm »
I removed the rear wiper and I didn't code anything.
No problems. No orders from the switch.
Because I'm curious I re-install the wiper and everything worked as it was meant to work.
Removed again and everything is OK.
Just black off the pipe so you have no leak from the fluid that is already in the pipe.
You don't have to code nothing.......from my experience.
                     Don't drive faster than your angel can fly..!
                Respect a man's car and the man will respect you
Offline RENNTAG
« Reply #7 on: January 01, 2012, 06:03:43 pm »
^^^^^Wicked, might do mine tomorrow then  :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #8 on: January 01, 2012, 09:37:54 pm »
so what happened if you had the stalk in the position for the wiper or you pressed for rear wash?
Diesel Daily Hack.
Offline pitsirikas
  • -Given: 19
« Reply #9 on: January 01, 2012, 10:11:23 pm »
When you have no wiper installed nothing happens even when you press the rear wash.......absolutely nothing.
If you re-install the wiper everything will work as before.....and the wiper and the rear wash.
