September 22, 2024, 07:37:10 am
All Things Mk5
How to Guides / Troubleshooting
MFSW vagcom coding settings
Topic: MFSW vagcom coding settings (Read 1867 times)
namz1
December 29, 2011, 08:21:46 pm »
I fitted RNS 510 recently and since having that fitted, iv realised i cant use the MFSW to go to the next track although the volume works from the steering, what could this be?
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Re: MFSW vagcom coding settings
Reply #1 on:
December 29, 2011, 08:38:40 pm »
you need to code
short press
and
untick BAP
then restart the RNS by pressing <> and eject
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #2 on:
December 29, 2011, 09:17:06 pm »
try it, if you have audio in the highline then the shortpress should fix it
stealthwolf
-Given: 306
-Receive: 291
ED30 No.1412
Reply #3 on:
December 29, 2011, 09:38:42 pm »
Do you have VCDS? You need to code the car with VCDS. If you have it then you need to look up how to use it.
The
GTI
isn't just a machine. It's very much a living, breathing thing.
All Things Mk5
