Author Topic: Awfull sound playing through ipod after installing mdi  (Read 6017 times)
Offline mortygttdi
  • -Receive: 146
Re: Awfull sound playing through ipod after installing mdi
« Reply #15 on: January 02, 2012, 01:16:26 pm »
Damo you need to take the stereo out and also take the blue plug out of the bigger black quadlock, once its out take the housing off the blue plug and take pin 2 out and put it back into pin 3, the earth is in a different place from gen 2 unit to gen3 unit.
Darren
Offline damoegan
« Reply #16 on: January 02, 2012, 04:47:38 pm »
Darren
Thanks Darren, will do it when the weather gets a little better.
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #17 on: January 02, 2012, 04:55:40 pm »
I had this Banham after installing the Kufatec MDI interface lead.
What it ended up being was at the back of the Kufatec quadlock, the speaker wires were loose (having used for it over a year, I'm not a huge fan of the quality of the Kufatec lead) and ended up in a very distorted crap quality sound from 2 of the speakers. CD and radio were unaffected, so sounds very similar to your problem.
I ended up wiggly those wires (I forget the colours off hand) and it improved/changed the quality depending on how they sat.
Check this firstly and I'd even have the unit out while playing music down the MDI while wiggling wires in the quadlock. You may find you aggravate one that changes the sound then that would appear to be where your problem lies  :happy2:
Pete
Offline Lyons
  • -Given: 18
« Reply #18 on: January 02, 2012, 10:56:08 pm »
Balls, im awaiting the Kufatec loom to be delivered!
Offline Banham
  • GTI MK6
« Reply #19 on: January 03, 2012, 06:44:25 pm »
Thanks, I will give this a try on sunday when i haev another play about with it as see if it makes a difference  :happy2:
