Author Topic: OEM Bluetooth FIT On MK5 Golf  (Read 11687 times)
Offline Usual Suspect
« on: January 02, 2012, 07:09:27 pm »
Hi everyone am in process of fitting an OEM BLUETOOTH KIT to my golf to work alongside my RNS 510!
I have got all the bits to include:
module
Microphone
And wiring harness
The problem I have is my wiring harness has 4 wires which are loose without a connector please see pictures.
These wires being:
Earth
Live
Can high
Can low
What I wanted to know was where I can buy a new harness from or a harness to join to these wires as i dont like to chop and tap into the original loom.
Basically I want to make mine plug and play.
Many thanks
« Last Edit: January 02, 2012, 07:28:39 pm by Usual Suspect »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: OEM Bluetooth FIT On MK5 Golf
« Reply #1 on: January 02, 2012, 07:25:18 pm »
Either car systems on ebay for a new loom, or take a look at http://octavia-vrs.com/cms/content/integrated-bluetooth for the bluetooth fitting guide, this shows how the original looms like you have there can be made plug and play "ish" with some repair wires.
Offline flyboy1976
« Reply #2 on: January 02, 2012, 09:46:39 pm »
http://www.ebay.co.uk/itm/VW-Bluetooth-Wiring-OEM-7P6035730C-7P6035730D-7P6-/170588943443?pt=DE_Autoteile&hash=item27b7e4b453
Thats what you want fella.....it even comes with the wires pre-made up with connectors so if you want to divert the mic into the sat nav (pins 1&7 /4& 9) to use voice control (vcds coding req'd) you can do so via their ''white'' A-D connectors.
« Reply #3 on: January 02, 2012, 11:58:05 pm »
Nice one fellas
Anyone have a good theory of making your own connector for the above 4 wires???
Many thanks
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: January 03, 2012, 08:07:10 am »
^^ Yes, take a look at the octavia site I linked, it lists the VW parts numbers for making your own connectors and joining these to the required wires on the back of the radio. You will need a pin removal tool for the quadlock on the back of the radio but it will be plug and play.
Offline apples12
« Reply #5 on: January 03, 2012, 08:28:44 am »
all you'd need is a bog-standard 'extension' cable for the quadlock connector which goes into the back of your HU
the brown wire is a ground, red/white is positive feed
can/low, can/high are what they say they are - pay attention to these however, they are twisted in a particular manner to reduce interference - something like one twist every 20mm or something (the exact specification is on my-gti.com) and away you go....
i've got genuine VW CAN bus repair wire about 9metres of it and one of these extension cables spare if your interested
MK6 GT TDI  - CW - LUX pack
GONE
« Reply #6 on: January 23, 2012, 02:51:13 pm »
Thanks mate will let U know!  :happy2:
« Reply #7 on: January 23, 2012, 02:52:34 pm »
Anyone know the part numbers for the bracket for the module and covers for the module?
Also screws clip part numbers for mounting it under the seat will be great
Many thanks
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #8 on: January 25, 2012, 07:02:18 pm »
« Reply #9 on: January 27, 2012, 03:55:33 pm »
This should help.
http://www.my-gti.com/1167/volkswagen-skoda-bluetooth-part-numbers
Thank u!
Is there anywhere I can by a quad lock extension cable? Many thanks
