Author Topic: Sparkplugs as well as Ignition Coils?????  (Read 2954 times)
Offline ED3030
« on: January 04, 2012, 07:03:15 pm »
A few weeks ago my ED30 started to misfire a little in the mornings on the way to work and then the morning after a 150mile trip it started to misfire like crazy (with engine warning light flashing).
Yesterday I changed all 4 coil packs and its loads better and I've no loss it power when warm. However, I still have a noticeable misfire when the engine is cold.
Should I have changed the sparkplugs when changing the ignition coils?
If so should I stick with OEM plugs or go for something more fancy?
Should I just bite the bullet and take it to the dealers (they've quoted £65 minimum to find the problem).
My ED30 is 4.5 years old, totally standard with DSG box and its covered 47,000 miles.
Many Thanks in advance.
Edition 30 2008
Re: Sparkplugs as well as Ignition Coils?????
« Reply #1 on: January 04, 2012, 07:18:53 pm »
Yup, change the plugs as well and oem ones will be fine for an unmodded car.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #2 on: January 05, 2012, 07:44:44 am »
06H 905 611
These are the ones you want   :happy2:
Offline ED3030
« Reply #3 on: January 05, 2012, 06:59:58 pm »
Cheers.....
Changed the plugs and the misfire when driving has gone but there is still a cough when idling but I can live with that until its next service.
Thanks again.
Edition 30 2008
« Reply #4 on: January 05, 2012, 07:07:19 pm »
Cheers.....
Thanks again.
I wonder if your pcv has a slight leak...
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #5 on: January 05, 2012, 08:23:00 pm »
 x2 Worth looking into. Cheap enough fix if you go OEM.
Have a look at this if you want to look into it
http://vagdrivers.net/forums/index.php?showtopic=40537
Just get the newer 'N' revision  :happy2:
Offline ED3030
« Reply #6 on: January 06, 2012, 11:20:16 pm »
Thanks again.....
Changed the PCV today and it's eliminated the misfire when idling.
Edition 30 2008
« Reply #7 on: January 08, 2012, 07:47:55 pm »
Thanks again.....
Happy days...   :happy2:
