Author Topic: Brake caliper plate???  (Read 7415 times)
Offline DJM
  • -Given: 28
« on: January 05, 2012, 01:36:42 pm »
Im after part number or name or any info really.
I seen on someones members ride thread that they had sort of plates on the brakes with a R on. Covered the pad in middle of caliper area. Could be seen through the wheels. Looked really good but cant find them anymore.
Was a VW part as far as im aware. Unsure if they had r32/s3 brake set up though. I only got standard brakes on my GTi but wondered if I could get them for mine.
Re: Brake caliper plate???
« Reply #1 on: January 05, 2012, 03:16:45 pm »
As far as I'm aware they are just wire springs on standard gti calipers.
The pad retaining clip/springs with the plates on are just on the S3/R32 calipers  :happy2:
Offline RENNTAG
  • Premium Performance Parts
« Reply #2 on: January 05, 2012, 03:25:18 pm »
I thought you could only get these for the r32/s3 set up?
« Reply #3 on: January 05, 2012, 03:55:16 pm »
Errr, yeah, that's what I just said....I think?
Offline RENNTAG
« Reply #4 on: January 06, 2012, 10:14:12 am »
Yes you are correct  :ashamed:
Offline DJM
  • -Given: 28
« Reply #5 on: January 06, 2012, 01:24:07 pm »
Cheers for clearing that up Monte. Shame cant get them on standard GTi calipers looks alot better imo.
Offline vRS_Pagey
  • -Receive: 59
« Reply #6 on: January 07, 2012, 10:44:47 am »
No reason why you couldn't have a piece of 2mm steel welded to the spring clip, then spray it all and fit a sticker???  When I painted the calipers on swmbo's GT (same calipers as the GTi) I removed the spring, it won't cause any problems while the brakes are fitted, just a thought!  :indifferent:
The S3 retaining clip does look good, but then I'm biased.......
Offline big al
« Reply #7 on: January 13, 2012, 01:22:58 pm »
Have you got the part number for the S3/R32 clip please?
Offline Beddie
  • -Receive: 76
« Reply #8 on: January 14, 2012, 06:01:57 pm »
8p0 615 269  - For the S3 version  :smiley:
Carbon Grey Edition 35 - Here
Offline big al
« Reply #9 on: January 15, 2012, 08:24:12 pm »
Is that def the right one? Only reason I ask is that I ordered a pair of clips before now and when they came they were the standard clips that have the metal square part on the front.
Offline Beddie
  • -Receive: 76
« Reply #10 on: January 15, 2012, 09:08:27 pm »
It's the right part number for the S3 version yeah  :smiley:
Normal R32 plain clip without 'plate' is:  1KO 615 269
Black with silver 'R' (Golf R and Scirocco R) is:  1KO 615 269 B
Red with plain Red 'plate' (MK2 Leon Cupra R) is:  1PO 615 269 - not checked this to be 100% correct as yet though
Offline AGray
« Reply #11 on: January 26, 2012, 09:47:42 pm »
Does this version fit the MkV R32 Calipers without modification? :)
« Reply #12 on: January 26, 2012, 10:01:29 pm »
Yes mate, straight on :happy2:
Offline AGray
« Reply #13 on: January 26, 2012, 10:16:59 pm »
Brilliant! Thankyou!
Offline big al
« Reply #14 on: January 27, 2012, 03:13:27 pm »
£50 a pair now.  :surprised: Managed to get some a bit cheaper though
