Author Topic: Lowering options  (Read 7611 times)
Offline Trekmeister
  • Golf GT 140
Lowering options
« on: January 05, 2012, 07:03:36 pm »
I have a a mk5 GT TDI which has stiffened factory suspension. I would like the car lowered slightly but want to keep the stiffness/firm ride and current handling characteristics. What are my best options, could I go for a shorter spring, coilover, dampers etc? (I dont want to break the bank either so want to keep the prices reasonable)
Brad
Offline GNJ_Motorsport
  • -Receive: 20
    • GNJ Motorsport
Re: Lowering options
« Reply #1 on: January 05, 2012, 11:26:11 pm »
Loads of options here mate-
http://www.gnjmotorsport.com/categories/Volkswagen/Golf-Mk-5/
When you say stiffened, do you mean it has uprated dampers?
I'd recommend coilovers as you can set the height to what you want and they will be stiff for fast road driving. The V Maxx kit is well priced.
0% Interest Free Finance Available On All Parts NOW
info@gnjmotorsport.com  -  01254 883345
Facebook  -  Instagram
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #2 on: January 06, 2012, 08:07:01 am »
Most people go for Eibach or H&R Lowering Springs on here. They are very reasonably priced and can be used in conjunction with your standard dampers without any problem. There are two common heights both these manufacturers supply springs in: a 20mm drop or a 40mm drop. I have had both versions on my car (from Eibach) and would recommend either to anybody.
p.s. I am selling a set of Eibach Sportline Springs for the Golf GT TDi here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,39116.0.html  :happy2:
« Last Edit: January 06, 2012, 08:09:43 am by dodds-gttdi »
Offline ni-coilovers.co.uk
    • stores.ebay.co.uk/ni-coilovers
« Reply #3 on: January 08, 2012, 11:29:31 pm »
Hi, you really need to read up on what your looking for.  A little education on each item will go a long way.  Once you have decided what you want then we can get you some prices.
Springs/Coilovers/suspension kit
We wont be beaten on price……..
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #4 on: January 15, 2012, 10:04:52 pm »
Don't mate Eibach Sportline springs with OEM GT dampers !!
These GT dampers aren't as stiff as GTI ones and they are too
soft for Sportline or H&R spings.
Go for Eibach Pro springs or Volkswagen OE springs instead.
For Eibach Sportline uprated dampers (Bilstein) are needed.
"You get what you pay for."
Offline Trekmeister
  • Golf GT 140
Re: Re: Lowering options
« Reply #5 on: January 15, 2012, 10:27:28 pm »
Whats the difference between sportsline and pro springs? Do VW do oe lowered springs for gt tdi with a 20mm drop?
Sent from my GT-I9100 using Tapatalk
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #6 on: January 15, 2012, 11:31:27 pm »
Sportlines are lower and stiffer than Pros. That's why stock dampers are able
to handle the Pros much better than the Sportlines.
Volkswagen Original Eqipment = Driver Gear are very popular in the USA:
http://www.golfmk6.com/forums/showthread.php?t=12098
http://www.volkswagen-zubehoer-shop.de/shop/product_info.php?info=p2315_Tieferlegungssatz--25-30-mm--max--VA-1050-1090-kg-Achslast.html
« Last Edit: January 16, 2012, 02:37:59 am by the bruce »
Offline Trekmeister
  • Golf GT 140
« Reply #7 on: January 16, 2012, 08:32:39 am »
Would the stock GTI dampers and springs be a straight swap onto the GT TDI or could I use the sportslines with some stock GTI springs, if so are these a cheaper option than the bilstein?
Offline Bikerz
« Reply #8 on: January 16, 2012, 09:35:20 am »
If you have a GT why would you want GTI dampers and springs? I would say it might go slightly lower as gti might have less stiff springs on front, however I doubt it would handle any better!
Offline Trekmeister
  • Golf GT 140
« Reply #9 on: January 16, 2012, 09:46:41 am »
Basically I want a slight drop nothing too drastic, want to keep a firm stiff ride but don't want to go overboard and replace the whole suspension system and I don't want coilovers. I was a little concerned the eibach pros might decrease my ride handling and give me a softer ride. I know when my rear spring was changed it was with a OE sports spring.
« Last Edit: January 16, 2012, 09:54:00 am by Trekmeister »
Offline mkviken
« Reply #10 on: January 16, 2012, 10:58:45 am »
if its just a slight drop you want with no harsh ride and slightly better handling its got to be eibach pro-kit springs. they're really good on OEM shocks
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #11 on: January 16, 2012, 11:30:42 am »
As has been said several times above. Eibach Pro Springs (-30mm) are probably the most ideal lowering spring. I have them on my car for these simple reasons: Cheap, excellent reputation, Perfect ride stiffness (same as OE) and they look good on the car with 17" or 18" Alloys.
H&R Springs, I presume will probably do the same job but having never had them I can't comment on comfort/stiffness etc.
HTH  :happy2:
Offline Trekmeister
  • Golf GT 140
« Reply #12 on: January 16, 2012, 11:32:37 am »
Having a hard time finding the pro kit for GT TDI can only find the sportsline for GT TDI
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #13 on: January 16, 2012, 12:22:56 pm »
I got mine from Demon Tweeks from their eBay store for £135 posted.  :smiley: Was gonna post up the link for them but I noticed the listing is ended. Maybe worth emailing/phoning them to see if they'll still oblige the offer price. Otherwise try:
DPM Performance
GNJ Motorsport
Car Parts Tuning - The Cheapest  :wink:
Offline Trekmeister
  • Golf GT 140
« Reply #14 on: January 16, 2012, 01:07:40 pm »
Thanks for the links however the pro kit dosent seem to list the GT specifically like the sportslines do?
