Poll
Whats you experience of the MK5 CC Stalk??
Never had a problem.
9 (75%)
Had problems, they must have been a friday job.
3 (25%)
Im watching celeb BB.... I dont care!
0 (0%)
Total Members Voted: 12
Author Topic: Cruise Control Stalk  (Read 4685 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Cruise Control Stalk
« Reply #15 on: April 02, 2012, 08:55:17 pm »
I've seen the wiper stalk fault a few times but it doesn't appear to cause the same level of problems as the CC ones.
Stu...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #16 on: April 02, 2012, 09:05:06 pm »
Technical Service Bulletin.
If your stalks are new take them back as they'll covered under new parts warranty.
The cleaning just prolongs the agony.
Surely this must apply to the A version stalks and not the newer G versions?
Cluster and Key coding
Location Great Yarmouth
Offline damoegan
« Reply #17 on: April 02, 2012, 09:07:31 pm »
Yea, it actualy causes both of us no problems at all. Just every time I san either car its there...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #18 on: April 02, 2012, 09:37:07 pm »
Yes the TSB applied to earlier stalks Eddie but the newer F or G versions shouldn't have failed if they were new and so should be warranted.
Quote
If the cruise control intermittently stops working or does not work at all when driving Octavia II vehicles at a constant speed, it is necessary to check the fault memory of the steering column control unit (Address group 16)
If fault code 00895 – “Cruise Control Switch – E45-faulty sporadic“ is stored in address group 16, the cruise control switch is to be replaced according to the Octavia II Workshop Manual (Binder 2, Chapter 94-7, Page 3).
The part number of the cruise control switch has not been changed. Only modified switches are available from spare parts stock.
Stu...
Offline Thor
  • -Receive: 25
« Reply #19 on: April 02, 2012, 10:14:42 pm »
Had the old style retro fitted on our old Leon Cupra and never missed a beat, not had any issues with the Eddy or SWMBO's MK6 either.
                                     Mk6 GTI
Offline apples12
« Reply #20 on: April 03, 2012, 09:48:29 am »
just noticed that my retrofitted 'old' style stalk on my mk5 is being a bit intermittent, will scan it for codes tonight...
is the only 'guaranteed' method to fix it swapping out the stalk for the later 'G' revision?
thanks
MK6 GT TDI  - CW - LUX pack
GONE
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #21 on: April 03, 2012, 08:25:33 pm »
If you have one thats failing then yes IMHO swap it out.
Stu...
