November 24, 2024, 08:02:15 pm
All Things Mk5
How to Guides / Troubleshooting
RCD510 - SD Card Error?
Topic: RCD510 - SD Card Error? (Read 5737 times)
john87
Won't Shut up.
-Given: 11
-Receive: 53
January 06, 2012, 09:59:14 am »
Sometimes when I switch on my stereo, the screen displays after several seconds 'SD Card Error' which is solved by either switching off and on or removing and replacing the SD card...it happens maybe 1 out of every 3 times I switch on the stereo and I can live with it, just wondered if anyone else has this issue
it could be the SD card that I've chosen?
Little_Dave
Won't Shut up.
-Given: 9
-Receive: 28
Re: RCD510 - SD Card Error?
Reply #1 on:
January 07, 2012, 12:35:37 am »
Never had this happen on mine........ have you tried another SD card instead to rule that out? worth a go mate
Dave
sanj
Won't Shut up.
-Given: 17
-Receive: 26
Reply #2 on:
January 07, 2012, 10:33:51 am »
As other members have said,try another brand of card,some make's do corrupt easier than others.
Last Edit: January 09, 2012, 04:59:17 pm by sanj
john87
Won't Shut up.
-Given: 11
-Receive: 53
Reply #3 on:
January 09, 2012, 12:35:54 pm »
cheers guys, that's probably what I'll do
Degudodger
Just look at my post count
-Given: 53
-Receive: 86
Reply #4 on:
January 13, 2012, 09:52:41 pm »
Had the same thing happen with a Sandisk 8GB card but only on start up and would only go away after removing the card and reinserting it. After a couple of weeks it got a little annoying so i took a rubber to the memory card contacts and after a couple of gentle wipes, no more errors
john87
Won't Shut up.
-Given: 11
-Receive: 53
Reply #5 on:
January 16, 2012, 09:58:47 am »
Did you use the 8GB card in an RCD510?
I bought a 2GB after reading in the book that 2gig is the maximum capacity
Degudodger
-Given: 53
-Receive: 86
Reply #6 on:
January 16, 2012, 10:07:08 am »
I have a 8gb Sandisk SD card in there at the moment but have also used a 16gb with out any issues.
james
Won't Shut up.
-Given: 6
-Receive: 19
Reply #7 on:
January 16, 2012, 12:17:41 pm »
i use a 32gb card works fine.
My build - K04 @ 400bhp (on some rr) ;)
http://www.mk5golfgti.co.uk/forum/index.php/topic,43854.0.html
john87
Won't Shut up.
-Given: 11
-Receive: 53
Reply #8 on:
January 16, 2012, 12:18:53 pm »
Nice to know... thanks chaps!
Kalpsn2000
-Given: 10
-Receive: 56
Reply #9 on:
January 17, 2012, 01:18:47 pm »
The early versions could not use SDHC cards that's why it was only up to 2GB. It changed at some point but not sure when.
john87
Won't Shut up.
-Given: 11
-Receive: 53
Reply #10 on:
January 18, 2012, 09:54:42 am »
I have now purchased a 16gb SDHC which works fine
takes a little longer to load up than the 2gb but this was expected
All Things Mk5
