Author Topic: Voltage dropping?  (Read 5304 times)
Voltage dropping?
« on: April 19, 2009, 02:30:07 pm »
I have a secret squirrel plan to install a few gadgets into the car, one of the things i want to do usually runs on a normal household 9v battery (the oblong type).
It's a device that is wired to a control box which holds the on off switch and the battery. Ideally what i want to do is install an on/off switch inside the ashtray to control it, but want to lose the 9v battery. Is there a way i can hard wire this to the car? maybe through the cigarette lighter? I would guess i would need to use some sort of inline fuse to protect it but there's tonnes of room under the ashtray area
any help appreciated  :innocent:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Voltage dropping?
« Reply #1 on: April 19, 2009, 05:29:51 pm »
Does the device have to run on 9v? If so the first thing you will need to sort is a suitable adaptor (you might be able to find a car mobile phone charger to do the job).
I would then run a dedicated cig lighter socket rather than tapping off from the existing one, there are plently of ignition switched 12v live points spare in the fuse box  :happy2:
What power/wattage requirements does this "device" have??
« Reply #2 on: April 19, 2009, 05:56:00 pm »
mobile phone charger eh... there's a thought
i dont know the full spec until it arrives from Hong Kong other than it runs off of a 9v battery
« Reply #3 on: April 19, 2009, 06:20:33 pm »
do you mean something like this?
Use Car Battery - Plug into car cigarette lighter socket
Changeable Polarity (negative or positive)
Switchable output voltage - 1.5, 3, 4.5, 6, 7.5, 9, 12v (800ma)
Complete with selection of jacks (Fit over 99% of appliances)
[ebay]120404786823[/ebay]
it's not very stealth though  :laugh:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: April 19, 2009, 06:29:41 pm »
Kind of  :signLOL:
The reason I suggested the mobile phone charger is because of the size of the multi voltage ones like that  :happy2:
« Reply #5 on: April 19, 2009, 08:41:02 pm »
From hong Kong you say, Me tinks iza nose wot it iz.  :party:
Offline WhiteGTI
  • F-A-S-T
« Reply #6 on: April 19, 2009, 09:42:47 pm »
Your putting neons in the car arn't you VC  :laugh: :laugh: :laugh:
2006 E46 BMW M3 - 343hp
« Reply #7 on: April 19, 2009, 10:43:31 pm »
 :chicken:
er.... NO  :grin:
« Reply #8 on: April 19, 2009, 10:46:36 pm »
VC quickly scuttles off and cancels order.  :grin:
I reckon its them fancy ignition light rings around the key entry.  :party:
« Reply #9 on: April 19, 2009, 10:51:17 pm »
nice idea that, but no... if this works/fails i will post it up but just need to sort out the drop...
need to splice more than one together too, guesing rather than needing 2 batteries they could draw current from the one although for only half the time? would it change the wiring to the car
Phil Mcavity
« Reply #10 on: April 30, 2009, 07:21:38 pm »
A high speed inflating Blow up doll for the passenger seat?
Offline 08micsta
  • -Receive: 63
  • Smart Fortwo 600cc
« Reply #11 on: April 30, 2009, 07:50:26 pm »
Try not to get too excited now Phil  :signLOL: :rolleye:
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
Phil Mcavity
« Reply #12 on: April 30, 2009, 08:27:41 pm »
That extra 9 volts no doubt give better inflation  :laugh:.
Sorry TC, do tell... What are you planning?
Offline 08micsta
  • -Receive: 63
« Reply #13 on: April 30, 2009, 08:30:48 pm »
Psst... Its VC....  :happy2:
Clearly the thoughts of 9V blow up dolls has distracted you....  :embarrassed:
« Reply #14 on: May 04, 2009, 01:43:21 am »
^^^^ :grin:
i've got it solved now, also now worked out how to 'disappear' it when i don't want to see it by utilising one of the standard functions of the car and modifying it  :evilgrin:
all will be revealed soon enough, it's now taken its place in the list of 'to do's'
