Author Topic: SuperPro's alternative to WALK kit....  (Read 4413 times)
Offline damoegan
« on: January 08, 2012, 10:55:19 am »
My console bushes are screwed so the cheapest way to replace them is to fit SoperPro bushes. These also gives the added benifit as being better bushes than you get in the WALK kit (aparently!)....
Now, the SuperPro bushed are acentric so my question is what is the correct orientation to fit them?
Any tips on what I should get the tracking set too?
Is this the correct orientation??
(pics borrowed from SteveP's thread  :wink:)
Offline vRSAlex
  • -Receive: 253
Re: SuperPro's alternative to WALK kit....
« Reply #1 on: January 08, 2012, 11:24:16 am »
The pic shows the bush in the anti lift position. If you have the bush facing the outside of the console then that is the extra caster position iirc. I used to have pdf with the full explanations on but its vanished.  A sheet will come with the bushes explaining the best orientation to mount the bushes.
Follow AKS tuning on Facebook
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: January 08, 2012, 11:26:07 am »
As far as alignment settings go then just stick to stock all round.
Superpro do their own wishbones now too. Have a look on their site a few newsletters back.
Offline damoegan
« Reply #3 on: January 08, 2012, 11:26:27 am »
Thanks Alex.
Offline jonbmx900
« Reply #4 on: February 18, 2012, 05:50:18 pm »
I was looking at doing this or the walk kit to my gt tdi
Offline robern2
« Reply #5 on: February 18, 2012, 07:52:39 pm »
interested to know why the superpro are better than the standard whiteline bushes ?
Offline vRSAlex
  • -Receive: 253
« Reply #6 on: February 18, 2012, 09:16:57 pm »
Slightly better compound and cheaper to buy.  The whilteline is an easier DIY fit where the Superpro ideally needs a press.
Offline mkviken
« Reply #7 on: February 18, 2012, 10:32:28 pm »
how do you know the insert is correctly orientated?
i personally would (and did) pay the extra and get the whiteline kit.
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: February 18, 2012, 11:11:42 pm »
Hopefully the fitter can install it correctly.  Comes with instructions to advise which orientation does what.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
SuperPro - alternative to WALK or just a compromise?
« Reply #9 on: February 19, 2012, 12:06:09 am »
(aparently!)....
What's better on them? There are Whiteline ALKs several years old without any visible
wear to the bushing. So it's bushing seems to be almost perfect.  :wink:
But from my point of view the most important difference is:
The Whiteline ALK changes bush position in three ways: lower, outward and forward.
How will the SuperPro be able to push it forward?
SuperPro is cheaper. But I don't see any point in being 'better'. Seems even worse to
me due to it's simple and compromised construction and the more difficult ( = expensive)
installation compared to Whiteline.
Don't get me wrong. Nothing against SuperPro who make proper bushes (superior in
quality to Powerflex). I just want to explain the difference and why Whiteline decided
to design their own differently shaped alloy console.
If you fit them even though turn them at a 120° position (outward + low). If you want to
preserve some amount of ride comfort you might drill some small holes into the opposite
site (there's still enough 'meat' in it). That's why the WL ALK also has these drilled holes.
 :wink:
"You get what you pay for."
Offline damoegan
« Reply #10 on: February 19, 2012, 12:30:50 am »
The fitter being me  :laugh:
All orientated correctly to my prefered setting  :happy2:
