Author Topic: Tyre Pressures  (Read 1336 times)
Offline am1w
Tyre Pressures
« on: January 08, 2012, 11:24:52 am »
Stupid question I am sure.
Must the car be on a level surface for an accurate  tyre pressure check or is it ok to check this when it's parked at an angle along a kerb?
Wolfgang: Tornado Red Mk6 GTI Manually Active 5 Door
Offline mad_pete
Re: Tyre Pressures
« Reply #1 on: January 08, 2012, 12:13:46 pm »
Should be fine assuming it hasn't somehow changed the volume of the tyre ?
Offline sanj
  • -Given: 17
Re: Tyre Pressures
« Reply #2 on: January 08, 2012, 01:26:25 pm »
Level surface and cold(first thing)as they will be wrong if you've driven about for a bit as this increases tyre pressure. :smiley:
Offline am1w
Re: Tyre Pressures
« Reply #3 on: January 08, 2012, 02:42:14 pm »
Thanks.
Flat and cold it will be.
Knew about the cold and always checked on flat surface.
Confirmation appreciated.
Offline mad_pete
Re: Tyre Pressures
« Reply #4 on: January 08, 2012, 03:50:55 pm »
The extra weight of the incline makes a difference ? So if I park one way on a hill take the pressures and then park the other I'm going to see a difference?
Thinking about it the spare is pumped up off the car (no weight) so I don't think the incline will matter much.
Offline am1w
Re: Tyre Pressures
« Reply #5 on: January 08, 2012, 05:00:27 pm »
I'll pump and check tilted and non-tilted but definitely cold.
