Author Topic: How much would a new xenon headlight cost from the steelers?  (Read 3675 times)
Offline oisinc
« on: January 10, 2012, 01:07:33 pm »
I'm getting quotes from dopes in the parts department of €119-€400 a side.
Anyone here quoted a recent figure?
Offline patrickcullen87
Re: How much would a new xenon headlight cost from the steelers?
« Reply #1 on: January 10, 2012, 01:19:26 pm »
bought a brand new headlight from a company on ebay for £150, no ballast or ignitor, just the actual casing
Admin Notice Sig Removed - Signature images should be no bigger than 450 pixels wide x 150 pixels high
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #2 on: January 10, 2012, 01:40:16 pm »
Don't forget you'll need the levelling system and headlamp washers to be legal with the new MOTs coming in...
Diesel Daily Hack.
Offline oisinc
« Reply #3 on: January 10, 2012, 01:49:06 pm »
I need to replace a unit which is cracked and letting in water. So I guess everything will need replacing?
No worries about MOT as it's factory fitted xenon
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #4 on: January 10, 2012, 01:50:22 pm »
Aww cool...
Diesel Daily Hack.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #5 on: January 10, 2012, 02:13:55 pm »
No, only if washers &  levelers are fitted are they tested. If they're not fitted then they aren't tested. MOT testers manual, section 1.7.  :happy2:
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline jhtrophy
  • Oh no it's a diesel
« Reply #6 on: January 10, 2012, 02:16:32 pm »
I'm pretty sure you have to have levellers and washers for xenons
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #7 on: January 10, 2012, 02:55:58 pm »
If fitted they have to work. Link.  :happy2:
Offline WT007
« Reply #8 on: January 10, 2012, 06:13:51 pm »
Today i took delivery of some hella Projectors they look 100% oe not sure if i will go halogen bulb or a xenon kit yet but at £337 delivered i am well happy.
Offline oisinc
« Reply #9 on: January 10, 2012, 06:55:23 pm »
back on topic please... :)
Anyone got a price for a complete (singular) Xenon headlight unit?
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #10 on: January 10, 2012, 07:06:43 pm »
2012 changes;
Lighting
Products on the lens or light source that obviously reduce the light's intensity or change its colour will become a reason for failure – applies to front/rear position lamps, registration plate lamps, stop lamps, rear fog and direction indicators,
Headlight requirements are updated to take account of the particular characteristics of High Intensity Discharge (HID) lamps.
HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective.
Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.
If a headlamp bulb is not seated correctly the resulting beam pattern will be indistinct and this will result in a test fail.
Diesel Daily Hack.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #11 on: January 10, 2012, 07:11:46 pm »
Not gonna get into (another) argument, but if you follow the link I posted above to the Official MOT testers online manual, you'll find what I've said is correct. Your section bolded stating
"Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems."
is not from the MOT test or VOSA.  :happy2:
Edit: It's from the AA who are trying their best to make a dogs dinner of the MOT test in their own words.
« Last Edit: January 10, 2012, 07:15:47 pm by Viking »
hugh jass
« Reply #12 on: January 10, 2012, 07:11:58 pm »
:popcornsoda: I need to see these and where did you getr them?
Offline apples12
« Reply #13 on: January 10, 2012, 07:49:03 pm »
if you purchase ONLY the OEM xenon headlight housing from the dealers that will be all you will need as your current bulb/igniter/ballast are OK im assuming and you'll be able to swap these over to the new unit, simple bolt on/bolt off for the ballast, and the ignitor/bulb/bulb holder ring are self explanatory
MK6 GT TDI  - CW - LUX pack
GONE
Offline JJ
« Reply #14 on: January 10, 2012, 10:30:58 pm »
I think you're looking in the region of £233.19 plus VAT for an OEM unit from the dealer.  I was quoted this price last year but it might've changed a bit since then possibly?
