Author Topic: Best manufactured year to purchase????????  (Read 3648 times)
Offline D. Diddy
« on: January 10, 2012, 10:55:16 pm »
What would be the best manufactured reg year to buy a car since? 06/56 onwards?
Offline Beddie
  • -Receive: 76
Re: Best manufactured year to purchase????????
« Reply #1 on: January 10, 2012, 10:56:02 pm »
2012 on account it would be the newest?
Carbon Grey Edition 35 - Here
Offline D. Diddy
« Reply #2 on: January 10, 2012, 11:00:29 pm »
Ha, yeah sorry! However i meant the MK5 as this is the 'MK5 GTI' website! Now that's two of us stating the obvious ;-)
« Reply #3 on: January 10, 2012, 11:02:29 pm »
Your question wasn't obvious though. Are you asking if VW had an off year.  :chicken:
Offline D. Diddy
« Reply #4 on: January 10, 2012, 11:06:04 pm »
Yeah because i heard they had to recall certain models for the coil pack change but was unsure of which year??
Offline Beddie
  • -Receive: 76
« Reply #5 on: January 10, 2012, 11:07:42 pm »
Coilpack recall was pre mid 2007 iirc?
As for the MK5 i'd go for as late as possible within your budget, push the boat out and get a 2009 Pirelli...  :happy2:
« Reply #6 on: January 10, 2012, 11:09:41 pm »
You can just take your car into any dealer and give them the details and they will tell you if it is on the recall list. so it makes no difference buying a car that might have the dodgy coil packs.  :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #7 on: January 10, 2012, 11:10:12 pm »
Yeah but older cars are built with tired/worn tooling... :-p
Diesel Daily Hack.
« Reply #8 on: January 10, 2012, 11:10:52 pm »
What?
Offline D. Diddy
« Reply #9 on: January 10, 2012, 11:16:16 pm »
Okay wicked thanks! But if you were me and wanted to purchase a mk5 GTI, what year manufactured would you opt for? Without obviously getting the most recent (58 plate) as I'm spending £10k maximum. . . . .
« Reply #10 on: January 10, 2012, 11:21:20 pm »
There is no discernible difference between year models. You just need to go for a car that has a full service record and the optional extras you would like. Keep an eye out for the cambelt service which is the fourth, if this hasn't been done, or is due you need to be aware that it is quite expensive.  :happy2:
Offline D. Diddy
« Reply #11 on: January 10, 2012, 11:25:32 pm »
Thanks alot, i really appreciate your advice! I don't mean to bore you but is there anything else inparticular that i should look out for?
Offline Beddie
  • -Receive: 76
« Reply #12 on: January 10, 2012, 11:25:55 pm »
^^ This  :happy2:
Condition and history for me is more important than age, get the best car that suits your spec 'wish list' and dont be afraid to haggle if it's above your budget, it's a buyers market out there!  :happy2:
Offline Beddie
  • -Receive: 76
« Reply #13 on: January 10, 2012, 11:28:58 pm »
A good solid VW service history, cambelt change at 60K/4 years if applicable, DSG service at 40K if you end with a DSG version..
Check for rust on the front and rear arches and sill ends..
Accident damage or repainting as you would with any car..
Check air con works correctly with no noises from the compressor, check ESP light is not permanently illuminated (ABS pump fault)
« Reply #14 on: January 10, 2012, 11:32:15 pm »
The air- con unit has been known to fail, and is expensive to replace, so make sure it works. If you plump for a DSG gearbox make sure it is smooth when operating. They have a mechatronics unit which again is costly to fix.
The best advice would be to spend a week on here first researching, this will give a good idea of the best spec and also a lot of cars are known to our members so when you find one you like the look of you can post it up on here and maybe get a history and some pearls of wisdom on suitability.  :happy2:
