Author Topic: Slight miss/hesitation and odd noise once switched off  (Read 2214 times)
Offline Soundlab
« on: April 20, 2009, 09:43:25 pm »
OK, had bit of strange one today.
Car was slightly hesitant on the way home work tonight...felt like it was missing slightly at low revs in 4th (at a fraction under 30mph).
Got home, let the car idle for a minute and then switched off.  As I walked around the car I could hear a strange noise.  It was most noticeable on the drivers side of the car...as I stooped down by the petrol cap I could hear a "glugging" or "dripping" sound coming from what seemed to be the petrol tank area.
Is this likely to be a bit of trapped air ?  I fuelled up late yesterday and hadn't had this problem until today (damn BP cr*ppy petrol !).
Any thoughts ?
Daz
Re: Slight miss/hesitation and odd noise once switched off
« Reply #1 on: April 20, 2009, 09:50:15 pm »
You do realize, Stealth wolf will not sleep tonight now and will be under his car as i post this.  :laugh:
I think you just thought it was to do with the juice, so you heard something in that area, that you would not normally be know where near.
Phil Mcavity
« Reply #2 on: April 20, 2009, 09:53:39 pm »
I have heard this before something to do with pressure realise valve back to the fuel tank. Sounds like a glugging sound more then anything.I wouldn't worry Soundlab, sounds like the same thing.
« Last Edit: April 20, 2009, 10:15:27 pm by Phil Mcavity »
Phil Mcavity
« Reply #3 on: April 20, 2009, 09:54:31 pm »
Slight miss/hesitatation would be something else. Is your Car Remapped or stock?
Offline Soundlab
« Reply #4 on: April 20, 2009, 10:13:29 pm »
It's completely stock.
It was audible enough that I managed to get a recording on to my phone of it ! lol !
Just seems a bit odd that the car was quite hesitant and then I had this noise 10 mins later.  I wouldn't be surprised if the hesitation is BP fuel related, my Skyline didn't like that stuff at all.  I only put the BP in as it was on the route home...
Phil Mcavity
« Reply #5 on: April 20, 2009, 10:16:54 pm »
could be a bad batch of fuel. No warning lights or anything?.
Offline Soundlab
« Reply #6 on: April 20, 2009, 10:21:31 pm »
Nope, no warning lights, etc.  Everything else seems fine.
Just got slightly concerned when I heard this "glugging" sound after switching it all off.  As you say, could be a pressure release  valve or something like that.
  • -Receive: 291
« Reply #7 on: April 20, 2009, 10:25:34 pm »
You realise I have a fear of being trapped under a vehicle and refused to change rims without chocking the other three wheels and placing the removed wheel next to the jack should the jack fail?
I also had a mate bring an ambulance and a fire truck round so if anything did happen, I'd be taken to hospital fairly quickly.
Furthermore I took the liberty of texting the ITU consultant and telling him what I was about to do just so he'd know what injuries to expect. I also asked him to inform the Trauma and Orthopaedics registrar so he could prepare a theatre on standby.
I then had a thiry minute long chat with immediate family members and told them I loved them. I also told them where my will was and where I had buried the treasure.
That's why it was 3pm when I had started to change the wheels and ran out of daylight.
  • -Receive: 291
« Reply #8 on: April 20, 2009, 10:26:53 pm »
Also, soundlab if you listen closely, when you put the key in and turn it, just before starting the ignition, there's a whole load of noises coming from the engine bay.
There's also some funny noises when you turn the car off and a little red light flashes too.
Offline vwrascal
« Reply #9 on: April 20, 2009, 10:50:16 pm »
 :signLOL: stealthwolf
