Author Topic: ETKA p/n request  (Read 3766 times)
ETKA p/n request
« on: January 13, 2012, 02:44:31 pm »
Can somebody please give me the pn of the thick rubber vacuum hose that goes from the front right corner or te inlet manifold just behind the PCV fitting.
Thanks in advance!
Mike
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: ETKA p/n request
« Reply #1 on: January 13, 2012, 03:18:29 pm »
Mike,
If no one replies i will get this for you when i get home later. May be Sat morning.
I think i know which part you mean but can you post a pic of it as if it's the one im thinking it's about £25 but comes as a complete kit.
« Reply #2 on: January 13, 2012, 03:24:59 pm »
Mike,
Thanks very much Carl.  Forge are sending me a couple of 6 and 8mm vac hose cut offs but I measure it as 7mm.
Will probably put me on but I want the oem bit on for piece of mind
« Reply #3 on: January 14, 2012, 09:57:38 am »
Mike,
Any joy Carl  :notworthy:
I spoke with John @ Forge yesterday afternoon and the vacuum hose cut offs arrived this morning!
Should get me on the road but I want the oem bit to be sure it's all propper
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #4 on: January 14, 2012, 10:15:26 am »
Sorry mate didn't finish till late last night.
I'll look now. Have you got a pic just so i am 100% at what I'm looking at? :happy2:
« Reply #5 on: January 14, 2012, 10:52:02 am »
No bother Carl, I know you had to have a go on your pipe before bed etc  :P
Pic shows what I had before. Whatever was there originally was butchered to insert a vacuum takeoff.
The vac hose John sent me was 8mm i.d but the manifold 'outlet' is larger than that so I reckon I need the oem bit
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #6 on: January 14, 2012, 10:58:49 am »
Are you referring to the pipe that goes to the dome shaped piece that is touching the ITG intake hose?
« Reply #7 on: January 14, 2012, 11:00:01 am »
Indeedy
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #8 on: January 14, 2012, 11:04:16 am »
i.e this bit
That should make it easier to find as i had to replace that on mine.
« Reply #9 on: January 14, 2012, 11:06:02 am »
That bit  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #10 on: January 14, 2012, 11:36:26 am »
EDIT - Found the correct part.
This is the correct part
Part No & Cost (knew it was about £25)
Just use small jubilee clamps to hold it on.
Got there in the end :happy2:
« Last Edit: January 15, 2012, 08:52:31 am by vRS Carl »
« Reply #11 on: January 14, 2012, 11:46:05 am »
Not to be the bearer of bad news but iirc that hose isn't sold seperately, you have to get the full servo piping that includes the hose.
« Reply #12 on: January 14, 2012, 11:47:45 pm »
i.e this bit
So bizzare...
Mum came over to visit today and brought with her the forge box that has my original rev C DV as it was in the out house gathering dust.
In the box was the original hose. It seams they didn't cut it up!  :smiley:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #13 on: January 15, 2012, 08:51:41 am »
Can you get me the rest of the part no. that's on that pipe. I'm wondering if it comes up on it's own as it isn't listed on it's own :happy2:
« Reply #14 on: January 15, 2012, 09:35:11 am »
