Author Topic: Gti disc swap ???  (Read 1221 times)
Offline Ducky76
Gti disc swap ???
« on: January 13, 2012, 04:28:31 pm »
Hi I set about swapping my worn standard rear discs and pads for some drilledn grooved + green stuff pads but following a how 2 thread on another forum but found out that tdi breaks and gti differ and I need a star bit bigger than 12 does any one know of a how 2 on here or on line cos I can't find one or is it just whip the star bolts out job done one got the piston tool????
Cheers andy
Re: Gti disc swap ???
« Reply #1 on: January 13, 2012, 04:30:23 pm »
It's a swine to get the spline bolts behind the calipers undone!
Offline chrisenright
« Reply #2 on: January 15, 2012, 08:10:17 pm »
+1.
No way do I ever put the standard bolts back on.
Always replace them with 10.9 hex heads.
Let's face it - if hex heads are good enough to hold the front calipers onto the car WTF were VW doing using splined socket head bolts on the rear?
The difference between genius and idiocy? Genius has its limits.
